Thread: Vec 1.9 cdti oil filter leak
    manchester
    Default Vec 1.9 cdti oil filter leak
    Can anyone help. Noticed an oil smell coming from the engine when stationary, checked under the car and noticed the drain pipe on the oil filter to be leaking onto the exhaust. I did an oil change replaced the oil filter and the two seals but it still seems to be leaking
    Has anybody else experienced this? Are the cartridges prone to cracking?
    I was thinking about bunging up the drain pipe to stop the leak.
    Any help or suggestions would be great
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    is the oil level dropping on the dipstick? 1st check I would do would be try tightening up the filter housing, maybe back it off a bit then retighten. iirc the drainhole is only open when the housing is unfastened past a certain point. also check for cross threading or that the seal has jumped off the cap as it was tightened ( had this happen on a HGV when changing fuel filter only found out when it pi55ed diesel everywhere) HTH
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What where the threads like when u changed the filter?
    manchester
    threads seemed fine when i had the cartridge. When I put it back i ensured the seals where seated and applied a small amount of oil on them so they wouldnt bined when putting back in.
    I might take a pun and replace the cartridge insert and see if it solves it
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by sr_fly View Post
    Was it leaking before you changed the oil filter? there is an oil vapour condensor just above the filter which on mine has a habit of spilling surplus oil if it gets backed up. may be worth giving engine bay a good clean with a steam cleaner in that area and check it after a few days, otherwise as you already said may be worth changing filter again and checking for cross threads or a damaged seal HTH
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Quote Originally Posted by clightowler View Post
    Same on my 1.9 150
    manchester
    I did an oil filter change because it was leaking from the drain pipe.
    I will check oil vapour condensor as well but its definatly coming from the drain pipe.
    Will phone the stealers and see how much a new cartridge is
  1. Oil filter housing leak.
    By Nez in forum Engine & Drivetrain
    Last Post: 12th December 2012, 16:31
  2. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  3. Fuel filter housing leak any suggestions?
    By Toe-side in forum Engine & Drivetrain
    Last Post: 11th March 2012, 12:00
  4. Fuel leak from filter housing
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2010, 23:27
  5. Diesel Filter leak
    By sri150 in forum Engine & Drivetrain
    Last Post: 28th November 2010, 18:20
vectra c cdti oil filter drain pipe
zafira sri 1.9 cdti oil filter housing
draining signum oil filter housing
vectra 1 9 oil filter pipe
astra 1.9 oil filter leak
1.9 cdti oil return pipe
