Thread: 3.2 lumpy idle update
    Regular Member DSmiddy's Avatar
    Jul 2011
    Bridgwater, Somerset
    Engine : 2.8 V6T
    Mileage : 50000
    Default 3.2 lumpy idle update
    Couple of weeks ago the car start idle like it was misfiring and the eml light was flashing, after plugging it up to computer it showed a misfire on 3 and 5.
    After changing the coil pack and all the plugs still no difference but the cambelt was done 4 days before on the Friday the car ran fine until Tuesday the following week.
    Took it back and got the timing checked and they found it to be very slightly out, after it was adjusted the car ran perfectly again.
    Just thought id share because I have seen a few posts about lumpy idle on the 3.2 and luckily found someone else with the same problem who found the timing was out which was what got me to check it.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Mines in for its belt and waterpump today hope i dont get the same problems
    Jul 2011
    Engine : 2.8 V6T
    Mileage : 50000
    Hope it goes alright mate (im sure it will)
    Regular Member Jezzy's Avatar
    S.E
    How do you adjust the timing slightly though - was it out a whole tooth?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    it would be down to a badly adjusted tensioner i think.. some muppet did the same thing to me old Veccy B. when I complained about it they offered me an engine flush, neadless to say i told them where they could put that idea. I eventually came across a retired VX tech, he listened to it and knew exactly what it was. An hour later it was sorted, i watched the job and he pointed to a tensioner that was not set right (looked fine to me but who am I to say), he then adjusted it to the position it should have been in. He was spot on, just a shame he was retired as he gained my confidence immediately.
    Mar 2011
    Farnborough
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Ah, maybe this is what is wrong with mine!
    Same thing, worth a shot that'.s for sure
    Cheshire
    because you have to juggle the 2 or 3 tensioners, it takes time to rotate the engine 720 deg each time, then refit the crank stop and gauge each set of cams. Professionals or 'corner cuttters' often omit this time consuming final check.
  1. 2.0t edition 100 lumpy idle
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 4th January 2012, 17:02
  2. lumpy idle 2.0 turbo
    By tecg in forum Engine & Drivetrain
    Last Post: 14th December 2011, 21:21
  3. Lumpy Idle + 1Gal/PH
    By Homer in forum Engine & Drivetrain
    Last Post: 4th November 2010, 22:16
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
