17" corsa sri 5 stud alloys?
Yes they will fit but the size of the tyres will look silly as the profile will be too small. You will ahve a massive gap between the top of the tyre and the wheel arch. Dont know if your original tyre would fit (probably 215/50/17) as wheels on the corsa wheels are most likely 195. You would need to check on the tyre size on corsa wheels.
Thanks mate. Was thinking of buying a set... but they aint got tyres on
Fair chance the offset will be too high causing them to sit further into the arches. They would look ok with spacers though
