Results 1 to 10 of 13
Thread: G3 compound by hand
    Jun 2011
    Newcastle
    Default G3 compound by hand
    Hi guys,
    So I bought a new spoiler, Painter it, Lacquered it and now I just bought G3 compound. I have tried rubbing it on by hand it does shine a little but I think a machine is needed. Has anyone else used it by hand and does anyone have any advice. A £15 spoiler is starting to cost a lot of money. TBF it was a genuine Irnscher one.
    Woodbridge
    Have you rubbed it down with wet n dry paper? I am guessing it has orange peel and over spray on it, if this is the case you will never get an amazing shine, Rubbing it down will remove that, then use the G3 to remove the sanding marks you will have created.
    Jun 2011
    Newcastle
    Used wet and dry and then g3 to shine. Should I wet and dry a bit more? Also whats orange peel? don't think I oversprayed. All looks nice and even
    Woodbridge
    Orange peel is when the paint surface looks the the outer skin of an orange, which you will never get looking it's best until you make the paint surface as smooth as glass. You can only remove orange peel by sanding it smooth. No matter how good the painter is you will always get it, some more experienced will get it less than others, but it is always there. G3 is very aggressive so it may have left its own marks in the paint, if that is the case you will need something less aggressive to go on top of the G3 after, a quick off the shelf product would be Meg's UC.
    Regular Member Jezzy's Avatar
    S.E
    G3 doesn't work by hand, get something like one of these drill attachments, then wet is and apply a little G3 to it; the results will be much better.
    http://www.ebay.co.uk/itm/POWER-DRIL...item5d2fa7edf1
    Jun 2011
    Newcastle
    I was looking for one of these......are they good?
    Jun 2011
    Newcastle
    Quote Originally Posted by Ginge7289 View Post
    I know what you mean now. No orange peel on mine though. I'm actually really impressed with the even'ness of the job. It looks really good except the laquer aint polishing up great. May have to try harder. I used 1200 grit on both the paint and the laquer for an even finish
    Woodbridge
    Do you mean it still looks hazey?
    Jun 2011
    Newcastle
    Just has not buffed up how I want. It got a little shine in places but not like the rest of the car. Just ordered the drill bit polisher to see if that helps.
    Woodbridge
    Which grade paper did you use? Was the final coat of colour shiny?
  1. Which compound is best?
    By Beardy in forum Detailing and Car Care Discussion
    Last Post: 12th November 2012, 12:30
  2. G6 compound?
    By Street Hawk in forum Detailing and Car Care Discussion
    Last Post: 24th August 2011, 12:09
  3. help cutting compound
    By paul.sessions in forum Detailing and Car Care Discussion
    Last Post: 6th May 2011, 06:08
  4. Just got some Ultimate Compound!
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 8th April 2011, 22:33
  5. Help compound advice.......
    By bobby-tupper in forum Detailing and Car Care Discussion
    Last Post: 23rd January 2009, 21:25
