Results 1 to 3 of 3
Thread: Boost pipe expanding..!
    dudley
    Default Boost pipe expanding..!
    car is a signum 2.0dti,
    The left hand boost pipe expands on boost, I only held the car at 2500-2800 revs and it had swelled up almost half its size, its also quite squidgy and seems to have no support in its walls, could this be the cause of my low down power problem, basically it has no poke at all, nothing.
    Milton Keynes
    It's probably gently leaking in several places too. Change it, change it, change it! Also, check the other boost pipes for splits carefully, especially behind them. A good workout for your fingers, too! Obviously, engine off and cold when you do this. Just thinking about this, it would be a good idea to clean out the intercooler as it could be causing some excess backpressure, but replace that pipe first for sure. It may be cheaper and more dependable to get a length of silicone hose than the VX part.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    defo look to changing the pipe but also the causes.. as mentioned disconnect your intercooler and flush it out asap
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
  1. boost sensor pipe
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th October 2012, 22:34
  2. What is this pipe coming off throttle body & why is it expanding
    By damers2000 in forum Engine & Drivetrain
    Last Post: 12th October 2011, 16:33
  3. New boost pipe
    By storm in forum Diesel Engine related
    Last Post: 30th August 2010, 20:58
  4. Boost pipe
    By SB3871 in forum Engine & Drivetrain
    Last Post: 15th July 2009, 11:50
  5. Boost Pipe
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 17:31
boost pipe expanding when rev engine
