Thread: Inlet manifold/drive actuator replaced!WOW!
    Regular Member martyboy's Avatar
    erskine
    Default Inlet manifold/drive actuator replaced!WOW!
    I now have my new inlet manifold and drive actuator fitted and car is now driving like a dream, no more smoke and miles better fuel consumption.
    I got the old ones back from mechanic and the drive actuator is fine to use but not sure about the manifold. Is there anything i can do (modification wise) to bring the old one back to life or is it just a case of binning it????
    Thoughts please as i dont know what to do with them....
    Why would you want to mate...? Assuming it's an old one and you've fitted a modified one, no-one would want a secondhand old one - if they were going to replace theirs they would buy a new one to start with...
    erskine
    Quote Originally Posted by Penfold101 View Post
    Just a thought. I know some People on here are into their engines and just thought there might be some scope for modification. Not to worry. I'll just bin them if they no good. Cheers
    Quote Originally Posted by martyboy View Post
    That's a thought actually - there were people looking at trying to blank off the extra holes completely as is done with it in the fiat version of the engine (I think), so it's not as silly as it first sounds. It's just such a ball-ache to remove it as I found out when I did mine...
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    93 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to correct section...
    erskine
    Quote Originally Posted by Big-Pete View Post
    Sorry, thought general chat would be ok. Will look further into it with next post. Sorry again Pete.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    what was your before and after mpg?
    erskine
    Quote Originally Posted by neill View Post
    Never very good as i drive about at night delivering chinese meals but i was 38-42 before and now i am 46 at worst under heavy driving. I have seen over 60 on a run where before i only got 55 on a run.
  1. Inlet Manifold Replaced ....
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:26
  2. Had Inlet Manifold Replaced ..... 1 Question
    By WeDesign in forum Engine & Drivetrain
    Last Post: 14th August 2012, 12:06
  3. Changing the inlet manifold + actuator on the cheap CDTi 150
    By Telly Addict in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2009, 15:28
  4. intake manifold/swirl actuator
    By John-joe in forum Engine & Drivetrain
    Last Post: 13th August 2008, 14:09
  5. inlet manifold / EGR valve/swirl actuator
    Last Post: 10th August 2008, 19:33
