Thread: vectra sri cdti 150 brakes
    wigan
    Default vectra sri cdti 150 brakes
    hi all is there sensors on the back brakes also back right making a grinding noise every now and agian is it worth me changeing the full lot?
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    on my preface only one sensor on the passenger front, if they're grinding its overdue lol
    Regular Member coooky's Avatar
    May 2011
    washington
    not sure about the sensors but for the money you might as well change both not that expensive got mine supply and fit £70
    wigan
    Default brakes
    thanks i used to use car every day but now its sat on front all day why im at work been reading a couple of threads it could be the caliper sticking on ? will get the back brakes changed nxt week
    May 2011
    washington
    Quote Originally Posted by stanlee View Post
    possibly i had that problem on my mondy and passat both needed a new caliper once off you can tell if its knackered
    11 Post(s)
    Sensor(s) are only on the front brakes. And there might be only the one; or none at all - depending on trim spec and age of your car.
  1. Vxr brakes on to a 1.9 cdti
    By toast in forum Suspension, Wheels & Brakes
    Last Post: 26th October 2012, 10:54
  2. 1.9 cdti brakes
    By homerj in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2011, 12:22
  3. Vectra vxr to 1.9 150 cdti brakes
    By johnnyboy1985 in forum Handling & Braking
    Last Post: 1st October 2010, 10:07
  4. CDTI 120 brakes
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 00:21
