Results 1 to 10 of 11
Thread: 1.9 CDTi 120 dramatic power loss.
    Jun 2009
    Cheltenham
    Default 1.9 CDTi 120 dramatic power loss.
    On Thursday accelerating through 3000 rpm in 2nd it lost power so abruptly that things in the boot fell over and it went absolutely flat and won't rev much over 3000 rpm even off load.
    Its a 1.9 CDTi 120, its runs smoothly on all 4 cylinders no misfire up nto 2500 rpm but there is no power, flat in 5th at 60 it shows 57 mpg and that's just about all it will manage. There is no exhaust smoke and I checked the EGR valve which is cleanish and seems free and just had Bayliss look at it and they say it is a leaking intercooler and stuck EGR valve.
    There is no hissing from the Intercooler or turbo whine so surely this can't account for absolutely no power and the way it stutters over 2750 rpm and just won't rev?
    It would account for no power below 2000 maybe but I have (some) torque below 2000 rpm.
    Any Ideas?
    Jun 2009
    Cheltenham
    Having no response at all on here I figured no power except a bit of torque around 2000 rpm and won't rev over 3000 off load sounds like a seized turbo so I got a Quote of £ 752 by Skurrrays to supply and fit a new Turbo, "But you should have a diagnostic check first," they said.
    Had diagnostic done by different dealer.
    Result Low Boost pressure caused by split intercooler and EGR problems.
    I only just cleaned the EGR Valve
    This second so far un named dealer fitted new intercooler.
    No different.
    "We think the Turbo's seized."
    That's what I told them in the first place, £470 ago.
    Jun 2011
    Elland
    Have you been through all the things listed in the two 'sticky' threads at the top of this section that are relevent to 'power loss' and 'problems'?
    Jun 2009
    Cheltenham
    Yes, I read loads of threads, according to the dealer the intercooler pipes are collapsing and squeezing in when you try to rev it and its undrivable, I think we all now think the Turbo has seized,hopefully the exhaust side or I'll have well it will manage 60 on the flat, no warning lights, emission or otherwise, just no power, some torque around 1000 to 2000 but tailing off.
    Most Threads are about a hole from 1000 to 2000 with some power when the turbo kicks in.
    I'll start stripping it down tomorrow, any ideas where I can get a good deal on a recon Turbo for a 54 plate Vectra 1.9 CDTi 120, 8 valve.
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    scary thing is this sounds like my car's problem :x
    Jun 2011
    Elland
    Just a comment, rather than help... but everything 'post compressor' is under positive pressure (assuming a working turbo), so the dealer comment that the pipes are sucking flat simply defies any sense whatsoever.
    However there is some sense if the turbo is doing nothing at all.
    First thing to take off would be the compressor inlet pipe and see if the turbine spins freely or not. Good luck, fella!
    Jun 2009
    Cheltenham
    I think the Turbo is seized solid, I'm trying to get to it now.
    Only just realised the airflow meter measures air coming into the turbo, so it meters fuel for the air leaking as well as the air being used by the engine, hence black smoke, I haven't seen that anywhere else on line.
    Jun 2011
    Elland
    Quote Originally Posted by david.broad View Post
    Yes it does! If a load of air is not getting to the engine, but the ECU thinks it is, then this will cause all sorts of problems... The ECU can probably compensate a bit from the manifold pressure sensor, but things like split intercoolers, hoses, etc. send the system generally haywire!
    Jun 2009
    Cheltenham
    Turbo wont turn, blades are in a bad way.
    Any ideas on where I can get a new/ recon turbo
    Nov 2010
    East Midlands
    Trim : design
    Got these on Ebay http://www.ebay.co.uk/itm/Opel-Astra...#ht_1106wt_990
    Not cheap - trouble with getting a secondhand one is it might be as bad as the one your taking off - might be worth trying breakers and getting a s\hand one off a vehicle that has been damaged and written off - providing impact has not damaged engine - bit risky whichever way you go - Good Luck with it
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  3. Replies: 4
    Last Post: 24th June 2008, 20:26
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
vectra c 1.9 cdti lack of power
vectra c cdti loss of turbo power
vectra 1.9 cdti 120 turbo problems site:www.vectra-c.com
1.9 cdti no boost
1.9 cdti 120 no boost
vectra c 1.9 cdti misfire at speed
astra 1.9 Sri power struggle an wont recv past 3000 rpm
vauxhall vectra 1.9 cdti 2006 sri misfire and lack of turbo
vauxhall vectra 1.9 cdti losing power
vauxhall vectra 2005 1.9 cdti wont go over 3000rpm
vauxhall vectra cdti no turbo boost
zafira 1.9cdti 8v no power
astra 1.9 cdti revs to 3000
astra h 1.9 cdti lack of power
vectra c 1.9 turbo loss
astra 1.9 cdti loses power when above 4000 rpms
vauxhall vectra 1.9 cdti 120 lack of power
vectra c missfire warning light
2005 vectra 1.9 sri turbo diesel no power
1.9 cdti low boost under 2500 rpm
vectra 1.9 120 loosing power
vectra c 1.9 diesel loss of power
drop in power vectra c diesel 8v
vauxhall vectra 1.9 120 8v common power loss
astra h 1.9 loss of power
