Thread: key fob problem
    Aug 2011
    Blackburn
    Default key fob problem
    Hi new to this so bare with me. Just baught this thing and already its starting to annoy me. I have a 04 plate vectra 2.0 sri turbo and all of a sudden my emission light has come on it was in limp mode which turned out to be the air intake sensor which I unplugged blew and replaced which has cured that problem now the light won't go so I presume this is to do with the cat but am not sure. Next problem is the switches on my door few buttens don't seem to do anything and finaly the key. The buttens don't work tried the batt and nothing so I presume this is dead. I do have a spare from my old vectra its the same type but how do I go about programming I have key pass. And to top it off normally there is a transponder chip wehich seems to be missing but car runs perfect please can someone help me !!! Thanks
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    use the search button mate there is loads of info on the keys, how 2s for the electric window buttons also, if it was your air intake sensor it will reset after 20 or 30 clear starts hope this helps
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Not sure if itbworks same on this but on older vauxhalls where put key in position 2 and hold lock/ unlock button after apron 30 secs all the doors should lock/ unlock to show key is syncd
    As for light have you had codes cleared since you repaired it? Try disconnecting battery for half hour see if you have any joy
    My passengerbswitch innmy vectra is a bit temperamental I thinknonly way is either stripnitndown check an clean contacts or renew
    Hth
    Adam
    Aug 2010
    Luton
    6 Post(s)
    Quote Originally Posted by oodjsparkiedeeoo View Post
    It's on the PCB, not separate as it was in earlier Vauxhall fobs.
    Aug 2011
    Blackburn
    does that mean when i change the fob the car will not start ??
    6 Post(s)
    Not unless you swap the guts from your old fob into the replacement fob, or have it re-programmed by Tech2.
    Aug 2011
    Blackburn
    ok so i have sorted out the passenger door switch and now its working. however the drivers door switch still baffles me. the passenger window switch works the drivers switch does not. the passenger mirror switch works and when you put it to drivers side the passenger mirror works backwards and again the drivers does not move. the key fob is now working after a little mod but when i lock the doors the drivers door does not lock on the central locking so i presume its a problem with the drivers door ?? considering nothing seems to be working yet the speaker works and some of the buttens on the door starting to get baffled now i know there is a control box on the door picked up a different one today which does nothing at all
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
