Results 1 to 2 of 2
Thread: Power Steering Failure
    Aug 2011
    Co. Durham
    Angry Power Steering Failure
    Hi,
    got a 2004 vectra, 2.0 litre which I have owned for a couple of months.
    The power steering suddenly failed last week with very little notice, just wondered if others have experienced this?
    It is like driving a tank without it, makes life very difficult!!
    Steering fluid level is full so its not that and I can't see any problems with the electrical connection..
    any ideas?? hopefully not the pump as i've forked out enough already on this car
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi db,have you any trouble codes stored,if not sometimes the spring in the checkvalve blockes the valve.the steering is electric over hydraulic,so a faulty alternator will give power steering failure,check the voltage across battery with engine running you should have about 14volts.
  1. power steering failure?
    Last Post: 20th April 2012, 16:38
  2. Power steering failure
    By Chris06v6 in forum Engine & Drivetrain
    Last Post: 28th July 2011, 06:22
  3. Power Steering Failure
    By gsi.vxr in forum Engine & Drivetrain
    Last Post: 26th October 2010, 15:01
  4. Power steering failure???
    By PeterVV in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2010, 06:37
  5. Power steering failure
    By Bobfish in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd August 2008, 19:59
