Thread: Cleaned and replaced but yet still nothing??
    Aberdeen Scotland
    Default Cleaned and replaced but yet still nothing??
    hi i have searched the forum for an answer but not anything coming up. My front washer jets are not putting out much water at all if any at all sometimes. I have done the filter cleaning, in fact replaced the filter and cleaned bottle and blown air through the pipes etc and needle in washers to solve any blockage issues. The water does get through but not alot and the pump is working, its like its not powerful enough to push the right amount of water through. Does anyone have any other solutions ideas? I have insignia washer jets that i will be putting in also just to verify that most things are new and should work thanks.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    does the rear jet work ok?..if not id consider trying another pump as they both work off the same pump/motor. If it does you either gotta blockage n replace pipes or try another set of wiper jets.
    Aberdeen Scotland
    no the rear one doesnt work either , so i guess it could be the pump on its way out.
    Aberdeen Scotland
    so does a vectra pump fit a signum?
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    you could either phone a dtealer n ask for both part numbers/prices or go to a breakers n look see..or wait for a answer
    Engine : 1.9 CDTi
    Yes they do.
    I have a working one here you can have for £7 delivered
  1. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  2. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
  3. Springs being replaced
    By connery-sri in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2010, 20:04
  4. maf replaced still need help
    By scutster in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:16
  5. 60k service and only oil replaced?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2009, 14:48
