Thread: VXR Boost Feed - Chuckleuk
    spoons
    Guest
    Default VXR Boost Feed - Chuckleuk
    For Chuckleuk....
    Here is the location for the 2.8 Turbo Boost gauge feed. Boost & vacuum
    You need to cut this pipe and fit a METAL T-Piece (6mm external diameter will do, although mine was a 6mm internal diameter but still just squeezed the fit). Dont bother with the plastic T-Pieces from Halfords as they break (it gets too hot, they weaken)
    Its very hard to get into the back of the engine bay with a camera... so its the soft rubbery pipe. Not the hard plastic ones...
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    Spoons you are a top man many thanks will get some pics up when it's fitted this weekend
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Old thread I no spoons what size pipe is it where u t in to as we did andys today but tue pipe I used it a bit big it works but when u thrash it it goes in to limp mode the pipe was hard plastic so swapped it for some other pipe but it's bigger that's why we gettin limp mode when u give it loads
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Spoons are you about matey?
    Sent from my iPhone 4 using Tapatalk
  1. Anybody in contact with Chuckleuk?
    By UncleMelon in forum General Chat
    Last Post: 26th February 2012, 23:42
  2. FAO: Chuckleuk
    Last Post: 23rd February 2012, 00:47
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
