Thread: CD70 Unpair/pair
    Aug 2011
    Vienna
    Default CD70 Unpair/pair
    Hi everyone. I am currently selling my CD70 on Ebay and thing is that i am selling only head unit without CID. As it is still paired as i don't have op-com will be buyer will be able to unpair it with radio/security code from my Car Pass which i own?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Needs to be unpaired before u take it out the car
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes it is possible. atleast with tech2..
    Engine : 2.2 Direct
    Nope can be done in the new car..
    Aug 2011
    Vienna
    Thats why asked because i am getting contradictory infos from different sources.
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by kenp View Post
    Needs to be unpaired with your screen before it can repaired with another screen
    Aug 2011
    Vienna
    Hmmm...still not any wiser. Here is what i found on op-com forum, few different scenarios
    So with the codes and an opcom unit will I have any problems divorcing the ECU from the car and the BID ready to sell?
    If you disable "Theft Protection" on the original head-unit, then this will keep things simple.
    And it should be okay for you to sell. Then the buyer should only need to re-enable theft protection with his own vehicles audio pass number.
    If I buy a new EHU that has been correctly divorced will it be simple to marry it to the car and BID?
    It is simple to marry to your car, if it has only been "Theft Protection" disabled.
    If it has been "RESET", then this can be paired up to your car, however EVERYTHING will need to be programmed into the Head-unit.
    If I buy a new EHU that hasn't been divorced but has a radio code will I be able to fit this correctly?
    You would need to fit this to your car, then disable theft protection with the donor vehicle audio pass code.
    Then re-enable theft protection with your own vehicle's audio pass code
    If I buy a new EHU that is sold as "needs coding", what will this in tail and is it possible with opcom?
    Sounds like the same thing to me as being totally RESET. - see above.
    May 2011
    bispham, blackpool
    for the sake of the hassel you will get off the buyer i would get it unpaired before you sell it as you know how buyers are on fleybay they will just give you a negative if you dont
  1. What a lovely pair!!
    By alanv6 in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2010, 20:56
  2. Wot A Pair!!!!!!!!!
    By payney in forum Quick Photo Album
    Last Post: 8th February 2006, 19:39
how to disable theft protection vectra c
