Thread: lack of power and shuddering
    Aug 2011
    denny
    Default lack of power and shuddering
    hi guys i have an 03 plate vectra sri 2.2 the problem is that when in lower gears car has no power and shudders need to take the revs right up on each gear,even on high gears car has no power its not nippy in any gear at all for a 2.2,someone said to me the problem is the air flow meter,when he disconected my afm on my car the car kept running he said this should kill the engine but never any help would be great guys the car is currently running like a bag of crap.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Disconnecting the MAF won't kill the engine, it'll revert to a basic map that doesn't make as much power and the engine may go into limp home mode with the management light on. The MAF can cause the car to behave like that though. It could also be a fueling issue. When was the fuel filter last changed? I don't think the older 2.2 engines suffered from dodgey fuel pumps - they only cropped up on the 2.2 direct engines but don't quote me on that.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    As above the fuel pump is nor a prob on the normal 2.2 do what the above says see what happens
    Aug 2011
    denny
    Default vectra shuddering
    cheers guys i changed the fuel filter the other week think it was the original and put redex through as well do u think changing the airflow filter will be the problem because i thought all along it seems as if the fuel is not getting through properly.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd ask in the regional forums on here if there is anyone near by that would let you swap the MAF over with a good working one from their car to test. The MAF sensors aren't cheap and buying a non Bosch/VX one can be a bit of a false economy - there's a lot of reports of them failing quicker and the car not running as well. If you've done the fuel filter then I would say the air intake side would be your next best bet.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    could also be your coil pack
    Aug 2011
    denny
    Default maf
    do u need to change the senors if ur replacing the airflow i was goin to buy a 2nd hand airflow meter from ebay but dont want to waste time and money i have read somewhere that vectras are prone to this shuddering and lack of power and cant be fixed that its in the computer and cant be sorted is this true.
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. vectra shuddering and no power
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2011, 20:24
  3. shuddering and no power
    By morrisseyno1 in forum West Scotland
    Last Post: 8th August 2011, 20:40
  4. Lack of Power
    By juggernaut in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 16:20
  5. Lack of power
    By reptar in forum Engine & Drivetrain
    Last Post: 20th November 2009, 20:00
