Thread: Fuel filter housing removal - 1.9CDTi
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Default Fuel filter housing removal - 1.9CDTi
    Just wondering if someone could help me - im probably being really stupid.
    Basically I'm trying to remove the fuel filter housing from the "crash box"
    Haynes manual states to use a screwdriver to depress the clip from the right hand side.
    Iv been trying for 15 minutes and haven't got anywhere, cant even see where I should be using the screwdriver!
    Any help appreciated!
    Thanks.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Jun 2011
    Elland
    I think it's the blue clips on the fuel lines (shown in the pic in the link above) that you need the flat bladed screwdriver for. My weapon of choice was an eating knife
    It's a bit fiddly the first time you do it - you need to get both of the lugs depressed in order for the pipe to pull out. Look closely at the joint and you will see that the lugs are what stop the pipe pulling out. HTH
    Redcar
    ~Were can you buy these blue clips cause mine seem to pop out slightly?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by rollercoaster63 View Post
    They do pull back slightly once fitted but as long as there is no leak don't worry
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by hebblemarine View Post
    And be very gentle with them as they are easily damaged
    Redcar
    There is a slight leak as can see the diesel around the plug. Need to keep it from popping out that little bit soeme how
  1. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  2. Fuel filter crash box removal mod - 1.9cdti engine
    By alcutler in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 23:19
  3. fuel filter housing
    By daddyjay in forum Parts for sale
    Last Post: 8th October 2010, 19:14
1.9 cdti fuel filter housing removal
https:www.vectra-c.comforumshowthread.php144212-Fuel-filter-housing-removal-1-9CDTi
vectra c fuel filter housing 1.9cdti
vectra fuel filter clips
vectra 1.9 cdti fuel filter housing
vectra 1.9 diesel filter housing removal
removing diesel filter housing vectra c 1.9 diesel
vauxhall blue fuel pipe clip removal
07 plate vectra diesel fuel filter housing removal
vectra diesel filter stuck
vectra c fuel filter stuck in housing
Zafira b fuel filter housing removal
