Results 1 to 3 of 3
Thread: 2.2dti belt tensioner
    Jan 2010
    cornwall
    Default 2.2dti belt tensioner
    My alternator belt tensioner on my 2.2dti vec c has just let go and looking for advise on whether its an easy fix or not. Being towed home by the AA wasn't what i had on mind on a Sunday afternoon.
    Regular Member eaglepva's Avatar
    Up North
    My tensioner went due to the bolt working loose then snapping so had to be drilled out. Tried to do it myself but the engine has to be dropped to get to the snapped bolt cost £120 to fix it.
    Milton Keynes
    It's not too difficult to do when you have the car up on axle stands and the drivers side roadwheel off. The most fiddly thing is getting the wheel arch liner off to be able to get at the tensioner from underneath. (It's best to push the little plastic rod in the middle of the wheel arch liner plastic fixing clips right through and make up new plastic rods if you can't find the old ones). There is a How To on this forum, I'm pretty sure. You need the new tensioner assembly and a new auxilliary drivebelt. Cheapest source is probably Fleabay.
  1. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  2. 2.0/2.2dti belt tensioner!?!
    By John LE in forum Engine & Drivetrain
    Last Post: 1st June 2011, 12:13
  3. Fan Belt Tensioner
    By betty02 in forum Engine & Drivetrain
    Last Post: 9th April 2011, 13:15
  4. Cam Belt Tensioner
    By frenchman in forum Engine & Drivetrain
    Last Post: 19th November 2009, 18:46
