Results 1 to 10 of 14
Thread: dual mass flywheel
    Aug 2010
    cheshire
    Default dual mass flywheel
    hi all i have got a sort of rattling sound when i put my clutch in i have a vectra cdti 150 05 plate with 35,000 on the clock the noise happens when i put the clutch in weather its in gear on neutral i have been told it might be the dual mass flywheel but with the mileage i was not sure could it be anything else less expensive ( i hope so) cheers all.
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Got same problem on my Saab 9-3 sport .....its 2007 with 47k.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    sounds like classic symtoms mate sorry
    Sodding Typical on Sea
    Sounds very much like the DMF is the car covered by the manufacturers warranty still?
    Aug 2010
    cheshire
    dont think so derek i bought the car 12 months ago and its an 05 plate so i think it would be out of manufactures warranty.
    lincolnshire
    bend over and be ready for penetration mate !
    As it goes the bill will be around £6>800.00 sadly. If the car had been under 3 years (not impossible with the low miles on her) then Vx would have had to stump up as they did on mine.
    Jan 2010
    wirral
    Quote Originally Posted by bembo449 View Post
    Jun 2011
    machynlleth powys
    if its the dmf the noise is normaly there with the clutch out and should stop when the clutch is pressed had mine changed and they were my symprons
    Jul 2011
    Essex
    I have the same problem, however I am on holiday with my family in Spain (and yes with the car). Will the noise get worse, or just stay the same? or will it go in a big way? just that I have a 1500 mile drive home in a couple of weeks and I am a little worried by the noise.
  1. Dual mass flywheel???
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 07:26
  2. Dual Mass Flywheel?
    By Gascon in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2008, 21:44
  3. Dual Mass Flywheel ???
    By diesel dog in forum Engine & Drivetrain
    Last Post: 1st December 2008, 11:33
  4. Dual Mass Flywheel...........again
    By Gaz the Cab in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 22:02
