Thread: does this look right to you ????
    Jun 2011
    machynlleth powys
    Default does this look right to you ????
    here is a pic of my injector wireing just wana know if it would lead to my vibration problem ?? car vibrates like hell when foot down .
    Regular Member coooky's Avatar
    May 2011
    washington
    well they dont look right there should be no bare wires tape them up and give it a blast maybe they have been touching each other
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    use self amalgamating tape, heat shrink would be better but would require splitting the wires and resoldering
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    is that vibration through the steering wheel ??
    maybe wheel balance ...or the VX syndrome of we cant find anything wrong with it .
    Jun 2011
    machynlleth powys
    no recently had dmf and clutch changed injectors tested one replaced (no:4) ran ok for a couple of days then one day the vibration started shakes the whole car
    scottish region
    Think its wheel balancing mate but get that wiring sorted
    May 2011
    washington
    have you checked your tyres ??
    i had a clio started to shake like mad took it to the garage and the mechanic ran his hand round the inside of the wheel nearly ripped his hand to bits as the inside of the tyre had worn down to the wires as it was faulty
    changed the tyre and never had the problem again
    what speed does the shaking start and it it just steering wheel wobble ??
    here is a list i found on the web for you to look into if its steering wheel wobble
    A list of possibilities
    Tires out of balance or the "bushings" (not sure the technical term) are worn in the steering system.
    It could be faulty steering dampers. This is a shock that crosses from left to right connecting to tie rod ends. The shock is very firm and you will not be able to actuate it by hand if working properly. usually causes left to right steering oscillation at low to mid speeds.
    Warped brake rotors for cars with front disk brakes. The rotor hits the caliper every tire rotation causing a small bump in the steering wheel each time.
    Your tires might need to be rotated and balanced.
    Check tires should be balanced, alingned or probably a bent front tire.
    Most of the time its only bad front tires now the one guy was right it can be bad brake rotors but what he didnt tell you is there is 2 things for that 1 is the steering wheel shaking when you are braking if so then you have warped rotors another thing when you brake does the car pull to the right or the left if so that will determine what rotor is bad and for but if it doesnt shake while braking that could mean your tires are cupped in the front or there not balanced properly.
    Depends when the wheel shakes. If it is during braking then your rotors are warped. If it is durinig normal driving then yes it could be bent rim, loose/worn suspension components. A balance problem is usually indicated by vibration in the vehicle not usually a shaky steering wheel. It may also be that the steering gear is badly worn which causes greater than normal spaces between the meshing parts.
    Out of balance wheels, bent rim, shifted belt in tire or other defect in tire including irregular wear (tire rotation under these conditions will on move the vibration felt), loose lug nuts, worn inner tie rod end bushings like mentioned on chrysler product above, loose mounted or internal play in the rack and pinion steering gear. Wheel Alignment or Front end Alignment will not cause a vibration.
    CV joint could cause this.
    Or a bent rim, which balancing will not fix.
    Check the lug nuts on all your tires. That did it for me.
    Shaking could also occur from camber being ofset as well as all! The other answers given above.
    Just had the same thing and it turned out to be worn struts which had caused my tire to wear unevenly (flattening one side of the tire). That caused shimmy at higher speeds.
    Also try new CV boots or a driveshaft replacement
    Jun 2011
    machynlleth powys
    thanks for the help guys but i didnt mention theres no vibration when clutch is in and you rev it like when your traveling at say 60 press the clutch .... no vibration so i think its something in the engine but i could be wrong
