Results 1 to 10 of 11
Thread: TPMS reading opposite corners?
    Engine : 1.9 CDTi
    Default TPMS reading opposite corners?
    Retro fitted the TPMS to my car.
    For about 3 weeks I was running around with it activated and showing readings from all 4 wheels even though I had only fitted the front receiver.
    I had noticed that it was showing a rear nearside tyre with low pressure. I checked them all and it was the front offside that had the low pressure.
    I put it down to it only using that 1 receiver.
    Yesterday I fitted the other rear receiver and the loom but its still the same.
    Has anyone else had the problem of TPMS reading opposite corners?
    Full Member Big Sig's Avatar
    Can you not just swap the wheels around?
    Engine : 1.9 CDTi
    Tyres are directional and I am not sure it works like that.
    I might take the rear trim off (Again lol) and leave it unplugged for a while and see if it resets itself.
    Actually i think your right, its not as simple as that
    Engine : 1.9 CDTi
    Just been out and disconnected the control box so will leave it like that for a few hours (Or till tomorrow).
    Took the wheel off to check for the leak and it was the TPMS valve. It was already tight and didn't want to over tighten it and break it.
    Ended up loosening the nut off quite away but not fully (Didn't want it to fall inside the tyre) and carefully pushed it back and wiggled it (Loads of air was escaping) for a bit so it would reseat. Did the nut back up and inflated tyre back up to correct pressure and it looks like its ok now (Poured water on the valve and no more bubbles)
    Just need to work out why its reading opposite now.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Lee have you had it Tech 2'd yet as you need to set the system to learn mode now you have the full setup. It also needs Tech 2 to set the warning limits that you want.
    Engine : 1.9 CDTi
    Not been Tech2'ed yet but the warning comes on at 29psi
    Need to pin my mate down to get it Tech2'ed.
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I think thats the answer Lee as the system has not been activated properly due to the receiver being missing the control unit has identified the wheel sensors but doesn't know where they actually are yet
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by paulhb View Post
    I had same problem Lee... I also had the problem of the 'Low Pressure' warning on all 4 tyres every time I started the car... I "opcom'd" my TPMS system in but Tech2 has more options to reset and setup the TPMS ECU. Once I'd had mine Tech2'd it was perfect.
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi lee
    yes the system must be tech2`d properly so the sensors learn with the
    recievers correctly,although your getting readings but their not true readings
    till its been programmed properly,1 of the procedures douring programming is
    that you have to take the car on a drive so the sensors learn with the
    recievers etc etc so dont be put off the info your getting atm cuz its not
    programmed properly.
    p.s i did tell you this while back it need programming properly
  1. ayr(opposite the train station)
    By borderlinechris in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 8th August 2012, 08:03
  2. Really twitchy around corners
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2011, 22:33
  3. Opposite door-light
    By LarsNorway in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2009, 13:00
  4. Top Gear - Vectra can't go round corners
    By ghostrider in forum Comedy & Humour
    Last Post: 3rd August 2007, 00:21
vectra c tpms relearn mode
