Thread: spinning ball joint
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default spinning ball joint
    i tried to remove the track rod end ball joint nut, but it stuck half way down, so tryng now to tighten it up and it just keeps spinning, any ideas how i can stop the ball joint spinning?
    cheers
    Engine : 1.9 CDTi
    Try and get pressure on the ball joint.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    need a ball joint splitter
    Feb 2011
    Selby
    Use a ball joint splitter to prise it out. The tool exists because more often that not they do exactly what you're experiencing now.
    You might be able to use a big screwdriver or some other lever to help push it down enough to stop it turning, but it's much easier with the correct tool!
    Mar 2011
    llandrindod wells
    http://www.ebay.co.uk/itm/Clarke-Qua...item4aad882b6e
    i've got one of these in my too box
    Jul 2010
    LIVERPOOL
    Vehicle : vectra c
    Trim : sri 100 edition
    Engine : 20t
    Year : 53
    whack the ball joint back into its seat,so it goes tight then take the nut off,then after that give the seat around the ball joint a good tap
    Jan 2006
    Hornchurch
    hit it with a hammer
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Excactly as sharky says. ;-)
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    cheers guys tried everything above to get the bleeding nut of, in the end i had to grind the nut of and get a new tre, what a ball ache
    cheers
  1. Ball joint issues
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 21:46
  2. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  3. Gearknob ball joint
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 21:57
  4. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  5. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
how to take ball joint off vectra c
