Thread: Engine
    Jul 2011
    birmingham
    rolleyes Engine
    Greeting all. I have purchased a Elite CDTI 150 with 102000 miles on the clock ex company car well serviced. Have fitted new cam belt and water pump and new A/C condenser. All running fine and dandy.
    Just noticed that when engine cover removed there is a link bar in the inlet manifold that clips onto levers going into manifold. This bar comes off after each time i reatach it. Is this important?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Swirl flap bar mate.
    Common problem. Sure there will be plenty of threads on how to sort it
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    very commen problem, ive heard of people opening the valves and superglueing them open and then detaching the motor underneath so it doesnt throw any eml on
    Jul 2011
    birmingham
    Default engine
    Thanks for replies. Just noticed 3 move easy and 1 stuck. What position should they be in?
    The one that's stuck is the one that is attached to the actuator motor below the manifold itself. The other 3 are moved by this one. These are called the swirl valves, and allow extra air into the engine at higher RPM and close off at lower RPM. If you rev the engine and watch them, you should see the valve moving if the actuator is still working. If it is, then it's just the build up of crap from the EGR system that's caused the valves to fail.
    Vauxhall fitted a modified manifold from 07 ish onwards, with a better designed system which is a lot less likely to fail. I changed mine a couple of months ago, along with my cambelt, and had the EGR system blanked off and mapped out so it's all running nice and dandy now with no crap build-up inside...
    Jul 2011
    birmingham
    Default engine
    Many thanks for that. I will give the recirculation a good clean and repair the ball joints. Mine was registered July 2006 so I doubt if it has the mod.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
