Results 1 to 3 of 3
Thread: air box mod
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Default air box mod
    tried searching but couldnt find,
    so can someone either explain or point me in the right direction of '2.0 dti airbox mod'
    as im going to get mine decatted , just wondered what the airbox mod was as ive seen a few people mention they done it after decat.
    thanks mel
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    The link below shows the 1.9CDTi.
    The 2.0DTi is very similar except the air box is fitted the other way round, ie, the pipe with the Mass Air Flow (MAF) sensor (as shown in photo) goes to the rear of the engine and not the front, but it is still on the same side of the engine bay.
    You also need to to unclip a metal bracket, holding one of the vacuum switches, that is also mounted on the airbox lid.
    The Electrical Connectors can be removed from the MAF by using a small screwdriver to gently prise the clip. Hard to describe, but easy once you do it once.
    Good luck.
    http://www.vectra-c.com/forum/showthread.php?t=15122
