Thread: Radio problems again!!
    Oct 2010
    Lincoln
    Default Radio problems again!!
    Thought I'd sorted my CDC40 reception problems as it's been fine since I checked the connections to the DAB roof unit but I now have another weird one.
    DAB working fine, turn on the rear screen heater and radio shows no reception, turn heater off and radio comes back again?
    Vectra C 56 plate.
    Any ideas please?
    Oct 2010
    Lincoln
    OK quick update on this weird problem. Get in car first thing and radio/DAB fine UNTIL I start the car. DAB says no reception. Drive for around 5 minutes, turn engine off and back on again and DAB is fine for the rest of the day!!!!
    ijk571
    Guest
    I had a very similar problem on my old mk3 mondeo. It would only do it on weaker stations or strong stations in a weak signal area. I couldn't tell if it was the rear screen or the heated mirrors causing it. But to cut a long story short I did an ECU reset (battery disconnected for 30 mins, for another reason), and the problem totally dissappeared, never to return, which baffled me!!. Maybe chance or worth a try??
    Maybe a bad earth? or a resistance issue with one of the elements corroded or broken? Worse in the wet or dry?
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    I would agree with the poor earth.
    The amplifier may be losing it's power dueto something else drawing off the current to operate.
    The golden rule of any electrical issue, is to pull the battery for 1/2 hour or so... this cures about 90% of electrical gremlins. (It is also free)
    For owners of vehicles with half CAN radios, only disconnect the battery if you definately have the vehicle pass card with the audio and security codes on it.
    Although from memory, it is almost always the Full CAN radios that play up.
    ijk571
    Guest
    Quote Originally Posted by Robsey View Post
    It's quite odd that a battery pull can cure some of these odd type problems.....
    Oct 2010
    Lincoln
    Thanks guys, I'll give that a try over the weekend but the very odd thing is that the DAB roof is aerial is fed down the drivers side to the front whereas the heated rear screen comes from the REC in the boot on the passenger side!!
  1. Radio Problems
    By Madaxeman in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2011, 01:43
  2. Radio Problems
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 19:43
  3. Radio problems
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2009, 18:11
  4. Radio problems
    By Robwilson in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 10:40
  5. DAD radio problems
    By stephen160 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 15:46
