Thread: Carb cleaner
    Sep 2009
    Glasgow
    Default Carb cleaner
    Hi all ran some carb cleaner throught the intake holding revs at 2.5 k hardly any smoke followed the how 2 guide, but when i removed the pipe holding it at 2.5 k there was no spanner light on dash ?, when i unpluged the maf i got the spanner ?
    Sep 2009
    Glasgow
    is my maf nackered
    Sodding Typical on Sea
    I would have undone the rubber hose at the throttle body end and shoved the pipe from the 10K in there and a bit of duct tape to form a seal. Then injected into the intake from that point.
    You might well have damaged the hotwire as it is thinner than a human hair and as such a little sensitive.
    Sep 2009
    Glasgow
    Followed the how 2 100%, what is the hot wire, it said in how 2 when removing pipe it should. Show error light,, there are no warnings of this on the how 2, is it wrong, if so it should be amended
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    If you disconnect the maf you will get the spanner warning, it should go out as soon as you start the engine
    If you followed the how to, then it might just take 10 full cycles to overcome the the fault light till it resets.
    Sep 2009
    Glasgow
    dont mean to be rude, but dont think you have understood the post, the how 2 states that on removing the pipe from the maf (with engine running)will throw the spanner light, but on mine it didn't, so i tested it by unplugging it and then it threw the spanner light, light has cleared as i used my code reader to clear it.
    Sorry, indeed I think I have mis-understood as you stated you think you have ruined your MAF in the initial post matey
    Has the spanner light gone or has it returned.
    Sep 2009
    Glasgow
    light gone, but why didnt it appear when i removed the pipe as stated in how 2, car running fine, what would be the issues with a dodgy maf
  1. carb cleaner through the inlet???
    By craig-s in forum Engine & Drivetrain
    Last Post: 7th March 2012, 21:30
  2. carb cleaner
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2011, 00:18
  3. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  4. carb cleaner
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 21:02
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
