Thread: CDTI 120Non Start
    Dec 2010
    kent
    rolleyes CDTI 120Non Start
    Bought a 2006 signum with a blown engine,fitted a used replacement from a car of same age ,all loom and wiring appeared same and connected but will not start ,when ign on fuel pump relay clicks on and pump only runs for a couple of secs before cutting out,can anyone give me some help as to where to look .i suspect a sensor is telling pump line is pressurised when it isnt ?is this a sensor in the tank pump or one of the two on the fuel rail ?
    any help much appreciated.i have been told that the high pressure pump is not coded to the ECU on these engines is this correct ?
    Dec 2010
    kent
    To update this i have been looking at the old and new engine and find that the fuel rail on the new one doesnt use a fuel pressure regulator only a sensor ,am going to swap them over and see if this cures it.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I thought the fuel pumps were coded also the injectors
    Irmscher Insignia CDTI 130
    Dec 2010
    kent
    Swapped the rail and regulator and after bleeding out ran lovely so pump and inj dont appear to be coded to ecu.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    think the injector coding is to do with the flow/volume rather than an imobiliser
  1. Cdti 150 non start!!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 15th April 2012, 16:27
  2. CDTI 120 difficult to start
    By matt_harw in forum Engine & Drivetrain
    Last Post: 14th November 2011, 21:48
  3. cdti smoke on start up
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 10:14
  4. 1.9 cdti poor start...!!!
    By rioni in forum Engine & Drivetrain
    Last Post: 26th March 2010, 21:24
  5. 1.9 120 cdti turns but won't start
    By weatherforcast in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 14:25
