Results 1 to 10 of 11
Thread: 2.0 Turbo idle control valve
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default 2.0 Turbo idle control valve
    Does the 2.0T have an idle control valve I can swear that I have read somewhere that they don't
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    not as far as i know mate...
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I believe it uses the same principle as the 2.2 in that there should be a tiny gap around the butterfly to control idle.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Can anyone show me a pic where the throttle body is and where I can find this butterfly valve please
    Worksop
    lumpy tickover?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    the big rubber hose that goes up the front of your engine and then connects to the block just above the dipstick, that part it connects to is the throttle body and inside that is the butterfly valve..
    see pic here in post 2 http://www.vectra-c.com/forum/showthread.php?t=101304
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    And this is the TB with the Butterfly, you can see the small gap so it doesn't make a perfect seal. On TB's with a ICV there would be no gap.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I wouldn't call it bad lumpy tickover it wouldn't stall but not as smooth as I'd like I was thinking of cleaning it
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Sounds about right mate, I'd say a dirty TB is what your looking at.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Off it will come then cheers guys
  1. idle control valve 1.9cdti 16v
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 1st October 2012, 10:03
  2. **Urgent help required - Idle Control Valve gasket**
    By Bloicy in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 18:13
  3. 2.2 Non Direct Idle Control Valve
    By BaileySRI in forum Engine & Drivetrain
    Last Post: 19th February 2010, 17:22
  4. Help! 3.2 Idle Control Valve Gasket Needed (Leeds)
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 12:39
  5. where is the idle air control valve on the 1.8 16v?
    By glencol in forum Petrol Engine related
    Last Post: 18th March 2008, 08:41
z20net idle control valve
https:www.vectra-c.comforumshowthread.php144132-2-0-Turbo-idle-control-valvepage2
vectra sri turbo tickover
vectra c 2.0 turbo idle
