Thread: issues with my vectra dti
    Jul 2011
    kent
    Default issues with my vectra dti
    hi all! got an 04 dti recently and just started having issues. first battery was knacked so changed the battery and it still takes time to start.
    also it appears to be in limp mode. the eml symbol is also showing. Had a look on other thread and noticed im missing the butterfly valve in my engine too (is this expensive to replace?). there also some tears in big pipe in pic here.
    Jul 2011
    kent
    will appreciate any helpful advice/ suggestions
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    the tears in the intercooler pipe will be the problem mate promise you that
    scottish region
    Surely that pipe would make it go in to limp mode mate its held together with the clips I would start with that
    Jul 2011
    kent
    how much will the pipe cost to replace?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    U could make one er try look for a thread by innes he has done it
    Regular Member Innes's Avatar
    Plymouth
    Blimey the hose looks screwed!! Here is the thread I started about making your own hose. Vauxhall dont sell individual hoses. They Only do the whole set for £120. You can get the moulded silicone hoses from £45-60 on eBay. It's now developed to a point where I've contacted a hose supplier who'll do a longer leg length and not need the metal elbow. Read the thread and you'll see what I mean. Page 6 and 7 are the latest developments.
    Plymouth
    I wouldn't worry to much about the butterfly missing. Some people took it off to aid low down grunt. The vacuum pipe gets blocked so it doesnt go into limp home mode. If the pipe is no longer blocked then that could be your problem. They were altered later on to not actually have the butterfly so it could also be the newer version that's not supposed to have it.
    Here is a pic to help you find your way around the engine bay. Don't worry that your vacuum pipes goes to left as they were re-routed in 2003.
    Jul 2011
    kent
    Quote Originally Posted by Innes View Post
    Hi Innes pls can you give me the details of the hose supplier so i can sort out my own hose?
  1. Help!!!! A few issues with my Vectra
    By Canaan in forum Vectra C / Signum Troubleshooting
    Last Post: 28th September 2012, 07:52
  2. vectra vxr starting issues
    By djmvxr in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2012, 19:14
  3. issues with vectra
    By vectra junkie in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2008, 00:46
  4. Minor issues with my new Vectra GSI
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2007, 11:36
  5. Various Issues Vectra 2.0 DTI
    By jmacp in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2007, 22:09
