Thread: Starter motor removal; how to do it?
    Jun 2009
    Brighton
    Default Starter motor removal; how to do it?
    Hi there guys, my starter has died (just spins up and whines without engaging with flywheel) and confirmed by RAC who towed me home.
    I cant find my ****** Haynes after tearing through the house ....
    Can anyone give me a very brief run down on how to take it off. Eg do I do it from bonnet side or underneath on ramps, how many bolts. is it easy etc.
    Anu help much apreciated... Thanks in advance.............
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    what engine is it
    Jun 2009
    Brighton
    Oh sorry i forgot to state the obvious.........Its a 55 plate 1.9 CDti 150 estate manual
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    3 bolts a think there 10 mm
    an a think it can be done from above.
    pretty obivious but make sure you disconnect the battery. i usually disconected pos and neg that way ensures no wires are live.
    adam
    Jun 2009
    Brighton
    Thanks for the reply. I am a bit wary of disconnecting the battery as alarm goes off and ill have to put codes in here and there. Aren't the cables on the starter dead until ignition switch energise it?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    starter is permenant live.
    the only code you have to put in is the radio code. and if you need to lock car etc while you wait on new one just tape end of pos cable at starter so it doesnt eart anywhere and connect battery cables back up and alarm will work as normal
    Feb 2011
    Not being a mechanic myself but also needing to change the starter motor is it just a straight foward job of remove wires, remove bolts, remove starter then re-install??? Any specialist tools needed??? Trying to save money and dont mind getting my hands dirty if its easy enough.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Simple as that mate. Just ensure the right wires go back in right place.
    Jun 2009
    Brighton
    Well i changed the starter motor in the end; not actually that difficult but pretty fiddly with big hands like me. I did the whole thing from bonnet side although I did remove the plastic shield from under the engine which helps when you inevitably drop a bolt or nut. There are 3 x 13 mm (spanner size) bolts; 2 on top and 1 under the starter solenoid bit. There is no room for a std 1/2 inch ratchet (too long). I could get a 1/4 in there on some of them with the 1/2 inch socket that makes a tight 13 mm. A selection of short 13 mm spanners will help. there are 3 electrical connections; 1 just the earth on the lower motor mounting bolt, 1 small wire on solenoid (key switch energized bit) and 1 large wire on solenoid that does the cranking once relay energised. I did disconnect the battery as Critch pointed out it is live all the time and when spannering this terminal to undo it YOU WILL hit other metal parts with the spanner which would turn the whole lot into a brilliant firework display. Once all free I moved the motor towards the right and temporarily shifted the water filler bottle (just clipped on) and pulled in through this gap. Motor was £130 + vat at Euro car parts. Vaux wanted £350 + vat but in their embarressment told me to contact Eurocar parts LOL. Many thanks for all who offered advice. I hope the notes hep others..........
  1. Starter Motor
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2014, 13:01
  2. Starter motor
    By lencuff in forum Y & Z30DT Specific
    Last Post: 9th January 2013, 21:09
  3. starter motor
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 11:06
  4. new starter motor
    By magpie27 in forum Engine & Drivetrain
    Last Post: 19th May 2009, 13:46
vectra 1.9 cdti starter motor removal
vectra c starter motor removal
astra 1.9 cdti starter motor removal
starter motor for vauxhall vectra 1.9 cdti
how to wire starter up on vectra
how to replace starter on vauxhall vectra
vectra c starter motor replacement
vectra c 1.9 cdti 150 starter motor
vectra starter motor location
how to change starter motor on vectra c
how to change astra h starter motor
how to change a starter motor on a vauxhall vectra
vectra starter motor fitting
vectra c starter motor change
fitting starter motor on vauhall zafiraastra 1.9 sri cdti starter motor diagramastra 1.9 cdti starter motorwheres my starter motor on vauxhall astra 05 1 8location starter motor vectra cwhereis the starter motor in my corsa 53 platesignum cdti 150 starter motor removal toolhow to locate the starter motor on a vauxhall signumhow to replace starter on 2.0 diesel vectra 2002vauxhall astra 1.9 cdti sri starter motor removal
