Results 1 to 10 of 27
Thread: axle stand points
    Jun 2011
    brum
    Default axle stand points
    I dont have a trolley jack, but im gonna use the standard scissor jack just to get the car up on stands. I know there not great, but i dont have much choice at the moment, the car's undriveable until i get the pads and discs done.
    My question is, i found the jack points (marked by arrows on the bottom trim) but where do i put the stands, been under the car twice but im still not 100% sure. Googled around and looked on here but i just want clarification as im not a mechanic, i dont know whats "sturdy" and what isnt.
    I found this pic from duncan (i think it was )
    Im guessing for the front, i stick the stands under that cylinder thing in the middle of the pic? Do i do the same on the back?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    wait for another reply but thats were i put mine to do a de-cat
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Where i put mine when i removed my pi's, sat there for two days no problems.
    Jun 2011
    brum
    fantastic, just wasnt 100% sure so thought id check before i go cause any damage since i dont know what half of the stuff underneath that car are for :P.
    Get the front done first then, hopefully its the same on the back and if not, someone will inform me where by the time ive done the fronts
    Cheers All
    Jun 2011
    brum
    well just jacked it up, got it on stands, got the wheel off and some idiot has already rounded off one of the calliper bolts (the ones with the bunges over). So looks like im gonna have to take it to a garage to get that bolt removed anyway. Why is nothing ever simple
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    can you not drill the top of then get out with some pilers once the caliper has realised
    Jun 2011
    brum
    problem is i dont have a garage nor driveway, im having to work on the car park of the factory over the road. So i have no electrical power whatsoever, and i dont have a battery operated one. i may be able to bash a 8mm key into it, or cut the rubber bung off and try mole grips. But im just trying to find part numbers e.c.t. now as im gonna need even more parts
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i always fix my axle stands to solid points around the suspension mounts, i also leave the wheels under the car as well just as a safety measure
    Jun 2011
    brum
    ha even better, no vauxhall garages are open til monday now. The parts departments closes between 1pm and 2pm.
    how safe is it to do the other 3 wheels (pads and discs) then do the drivers side next saturday ? i know your supposed to change them in pairs but i need to be in work monday. Or should i only do the pads and leave the dsics til i can do them in pairs ?
    Mar 2011
    llandrindod wells
    fit pads, dont do 3 and leave one as it will cause a break imbalance
  1. Front jacking points, and using axle stands
    By PeterVV in forum General Chat
    Last Post: 25th July 2017, 14:27
  2. front axle stand points
    By Grimo72 in forum General Chat
    Last Post: 14th May 2010, 02:49
  3. Jacking/axle stand help
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 10:09
  4. Axle Stand Location?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2009, 11:45
  5. Trolley jacking points & Axle stand locations?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 14:26
vectra c axle stand points
