Thread: Bonnet Release problem
    Jul 2011
    Heanor, Derbyshire
    Default Bonnet Release problem
    Got a small problem i am sure someone can help me with
    The bonnet release doesn't work on my car, first time i tried to open it today after buying the car (it worked when i test drove it !)
    Now the cable is connected at the pull handle just inside the drivers door, but as you pull it you can hear it in the engine bay, but it does not operate the catch.
    So i think it has either become disconnected at the mechanism under the bonnet or the cable has snapped.
    Here is the question then, how the hell do i open the bonnet to have a look?
    Any help appreciated.
    Matt
    newport
    try getting some one to push down on the front of the bonnet as you pull the handle
    Jul 2011
    Heanor, Derbyshire
    Quote Originally Posted by taffy bhoy View Post
    Tried that but there is no tension at all on the handle.
    West
    you're probably going to have to go through the grill to get to the mech, then adjust the tension on the cable once you've got it open... as per the howto
    Jul 2011
    Heanor, Derbyshire
    Just been out to it again a pulled the handle as far as it would go (i almost thought it was going to snap) and hey presto it released Looked at the how 2 and adjusted the cable and it now works perfectly.
    Thanks for your help
    Matt
    scottish region
    Vectrac saves the day again lol
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    how do you get to the mechanism, stupidly tried the how to and pulled the cable the wrong way so now it doesnt open at all, doh!
    Jul 2011
    Heanor, Derbyshire
    To the right hand side of the "v" in the grille the bonnet catch lever runs there, not sure if you can operate it with a pair of pliers?
    Someone a bit more knowledgeable will hopefully reply
  1. 2.8V6 bonnet release ....do it now !!
    By Deztroyer in forum Bodywork & Interior
    Last Post: 14th June 2011, 22:45
  2. Bonnet release
    By Admishere in forum Bodywork & Interior
    Last Post: 23rd March 2011, 15:26
  3. bonnet release
    By ade0303 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 20:39
  4. bonnet release
    By magpie27 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 14:08
  5. Bonnet release problem
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2008, 23:58
vauxhall vectra bonnet release problem
bonet release broken vectra c
vectra c bonnet cable snapped
vectra 2006 bonnet catch
vauxhall vectra bonnet catch stuck
bonnet catch not working vectra c
