Page 1 of 11 123 ... LastLast
Results 1 to 10 of 103
Thread: TC wiring
    Oct 2006
    southampton
    15 Post(s)
    Default TC wiring
    Right, I know there is numerous threads relating to T/C and how to make it work but I remember reading there is one wire that goes to the ECU then to the T/C swith that is missin, apparently it can be retrofitted.
    Any one shed so fresh light on this for me please...
    Oct 2006
    southampton
    15 Post(s)
    Bump
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Clive if yu don't have TC at all then you will need a different ABS control unit, the switch only disables the ABS and does not enable it unless you have switched it off with the switch first which you obviously haven't.
    So first things first do you have it have you ever had the light on with the wheeels starting to spin?
    If not then you don't have it and some installation time parts and Tech 2 required.
    If you have then the switch needs the wiring which is pin 3 or 4 on the ECU I believe but need to check this.
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    Heres the wireing diagram for the switch if it's not plug and play, if you don't have TC you need another unit.
    http://www.vectra-c.com/forum/showpo...&postcount=111
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    hummm maby i should do that to mine
    Oct 2006
    southampton
    15 Post(s)
    Cheers Paul and all peoples, I do have T/C so its just a case of wiring the switch then. Well chuffed now, specially with a wiring diagram too...
    Engine : 2.2 Direct
    Im about to put that in mine
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    So this red wire goes from the abs unit to the switch is that right any one got any piks please
    Engine : 2.2 Direct
    X1 is the BCM mate not the switch.. (and to pin 26).
    If you have the wiring for the switch then yes thats the only one.. (im also missing the wiring for the switch)
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Might sound stupid mate what's the bcm and where is it lol
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
how can i get a wire from the engine bay to the footwell in a vectra c
