Results 1 to 10 of 19
Thread: Does the airbox mod affect fuel consumption?
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Does the airbox mod affect fuel consumption?
    Am I right in thinking that this mod involves cutting out the extra bit of tubing inside the airbox? Firstly what benifits does this give you? Once it's done will it affect fuel consumption? Any pics of an airbox with this done would be nice.
    Regular Member bigdave1701's Avatar
    York
    More airflow so in theory better performance but the reality is you'll probably not notice any difference.
    Oh and no, it doesn't alter the fuel economy
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The only change in economy I can vouch for is that the vast majority of the air filter element surface is being used once that air guide is removed, rather than something like 40% of the filter element being used with the guide in place.
    Liverpool
    it improves airflow into the box and as said above mate it lets the whole airfilter be used instead of half of it (you'll see for urself when u open arbox)
    does run smoother (IMO) too
    I put another intake in the back of airbox aswel ste, pics are somewhere in diesel tuning section
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I did this on my 1.8 vvt and it got rid of the standard judder in 1st when pulling away. Made the car much smoother to drive as well. Have not seen much of a difference in fuel economy. I believe I get around 0.2 mpg extra now. What did make my mpg go down though was going to 225/45/17's. I lost around .4 mpg overall
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    you will probibly get a tiny winy bit better fuel consumption as the throttle response is better ....so once you have stopped booting it and gone back to normal driving it will be apparent
    West
    in addition to the above...
    there's no need to cut anything, the part in the airbox just unclips, imo you should only be removing the part from the lower half of the box & leave the trumet in the lid in place
    Jul 2011
    UK
    Year : 06
    Yer as above just unclips done it on my 150 cdti hear the turbo more but tempted to put it back on as mime seems to be useing fair bit of fuel than used to 30 pound in and couple days nearly gone miles left in tank goes down fast is this normal tho?
    Regular Member Exclusive BV's Avatar
    West Midlands
    I had always suspected that that judder in 1st on a 1.8 VVT is caused by inadequate airflow going to the sensor. If i revved it a few times first and let it settle and then took off, it never juddered so that cant be the clutch.
    This MOD pretty much confirmed it.
    TOPROD:- There is no need to do any 'Cutting'. The part in question just popps off. and if you search the howto section it's all in there.
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    TopRod heres a picture of the box with the funnel removed.
    This is the "1st stage" to the air box mod, very simple.
    Just un-clips and allows the full filter to be used.
    Hopefully the image helps.
    (Excuse the dirt of it)
  1. Best Fuel Consumption
    By Vauxhall-Vickie in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2010, 19:15
  2. full consumption after airbox mod
    By KevinG in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 22:42
  3. BC Fuel consumption
    By BigP in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 17:27
  4. fuel consumption on v6 dpf
    By lexicon in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 23:47
fuel consumption if I open the airbox
pictures for air box vectra c vvt 1.8
