Likes Likes:  8
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: H.I.D's fitted to facelift Vectra - How I did it (Pic Heavy)
    Regular Member Deann's Avatar
    Mar 2011
    England
    Default H.I.D's fitted to facelift Vectra - How I did it (Pic Heavy)
    Hey guys,
    Whilst fitting my H.I.D's I took plenty of pictures for my friend who also wants to do the same mod to his car.
    I was going to submit this as a how-to but there are already how-to's in the how-to section and I wouldn't want to try and replace any of the guides that another member has clearly taken the time and effort to write. (Also I couldn't get the pictures down to the 100kb limit in order to post them on the site).
    I purchased them from CARMODSHOP and when I came to fit them I decided to go for the method of removing the bumper and headlights and mounting the ballast underneath the headlight. Here's my efforts...
    Step 1
    So basically I started off with my facelift Vectra, Bonnet Open.
    Step 2
    I turned full lock on the wheel in order to gain access to the torx screws.
    Step 3
    Using a T20 torx alan key I removed the 2 screws
    Step 4
    I then turned full lock in the opposite direction in order to gain access to the torx screws on the opposite side
    Step 5
    Again I used a T20 torx alan key to remove the 2 screws
    Step 6
    Next up, using the same T20 alan key, I removed the 4 x Torx screws from the top of the bumper
    Step 7
    Underneath the car there are 4 plastic push-type clips with a thin plastic rod going through them. Locate these 4 clips and, using pliers and a screwdriver, prise/pull the plastic rod in order to free the clip. (See Step 8 & 9)
    Step 8
    This picture shows the thin plastic rod half removed
    Step 9
    This picture shows all 4 plastic clips to try and show what they look like and how they work.
    Step 10
    Although it doesn't feel natural, you need to give the bumper a firm pull in the direction shown in order to release it (best to pull outwards but place your hand towards the top of the bumper where the 1st arrow is located)
    Step 11
    The bumper should come away nicely
    Step 12
    Again, repeat step 10 but for the opposite side
    Step 13
    The whole bumper should now be free and drop onto the floor
    Step 14
    Before the bumper can be removed completely, ensure you disconnect the drivers side foglight
    Step 15
    And the passenger side fog light
    Step 16
    And the air temperature sensor
    Step 17
    Next I removed the headlights, there are 2 x 8mm bolts on top
    Step 18
    And 1 x 8mm bolt underneath
    Step 19
    Before pulling away the headlight from the car ensure that this clip is removed, just pull the red tab
    Step 20
    And it should come away like this
    Step 21
    Your Vectra will look a little bit like this
    Step 22
    In order to mount the ballast I located the space underneath the headlight which is already dedicated to the factory fitted xenons.
    Step 23
    I made use of the pre-drilled holes and fitted 2 x self tappers
    Step 24
    I then fitted the bulbs for the H.I.D's by first drilling a big enough hole in the headlight cover and feeding the wires through, all secured nicely with the grommet provided
    Step 25
    Finally I mounted the ballast with double sided stickey foam and I ty-raped around the ballast and the self tappers to ensure I nice snug fit (this is not shown in the picture but basically I wrapped the ty-rap around the 2 self tappers and around the ballast)
    Regular Member Garfo's Avatar
    plymouth,devon
    cool m8
    did that take u a day?
    11 Post(s)
    Quote Originally Posted by Garfo View Post
    I fitted mine in the same way. Took me just over an hour.
    Pic of mine with the cable tie attached, securing it to the headlight and making use of the self tappers.
    Blantyre
    Handy tip for the 4 x rivots underneath is to replace the long black insert with some self tappers, save you destroying them everytime you take them out
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by spennny View Post
    Long plasterboard screws are a perfect fit and nice and easy to get in and out because they are a wide thread, used them on both my Vecs now
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Nice tidy install.
    Good tip for the undertray guys.. will be doing this myself.
    Woodbridge
    Really good guide.
    11 Post(s)
    Quote Originally Posted by Deann View Post
    Step 10
    No firm pull is required if you partially undo the top screw in the wheelarch (step 5), push it back in then remove the screw completely. This releases the sliding lock mechanism that holds the bumper to the wing. Tightening the screw on re-assembly locks it back into place again.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    fantastic how2..... well done!
    is there a slot for the ballast to sit in on the pre-face lights?
    al.
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Good write up, this is exactly how I did mine. Keeps everything tidy and out of the way.
  1. My Vectra Diary ( PIC HEAVY )
    By mattbrad30 in forum Vehicle Diaries
    Last Post: 6th May 2013, 11:34
  2. My Mini facelift..... (Image Heavy)
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2011, 12:57
  3. Facelift Vectra Sri Bumper with XP Splitter Fitted
    By Fireyfella in forum Parts for sale
    Last Post: 13th December 2009, 13:28
  4. btcc diffuser fitted - pic heavy
    By darko2301 in forum Styling
    Last Post: 24th May 2009, 22:21
  5. Replies: 0
    Last Post: 17th March 2008, 22:03
https:www.vectra-c.comforumshowthread.php144064-H-I-D-s-fitted-to-facelift-Vectra-How-I-did-it-(Pic-Heavy)&goto=newpost
