Results 1 to 10 of 13
Thread: Electric sunroof not opening
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Default Electric sunroof not opening
    Well what a lovely boiling hot day it is here in Skegness but went to open my Sunroof and nothing happened, no tilt or slide.
    It was factory fitted on my Signum Elite can anyone suggest where I should start looking or testing, or which fuse it should be running off
    Many thanks in advance
    Sigmacca
    Glasgow
    Not many people have them, I'm sure the fuse locations are in the owners manual.
    Feb 2011
    May sound daft but have you took the key out of ignition and tried again. Happened once on my vectra elite, sunroof not working. Took key out. Put it back in, tried again and worked fine.
    Jun 2011
    Skegness
    Quote Originally Posted by elite150 View Post
    Yes mate, tried that, just being lazy and asking what next, guess are check the fuse next
    Jun 2011
    Skegness
    Well it's fuse number 3, checked it but is ok, pulled overhead panel off and wiggled the flat wires but still not working....
    Any idea's what to do next??
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Try the limit resets...
    Ignition on
    Switch to full closed..... press and hold switch for 5 secs.
    Switch to full open.... press and hold switch for 5 secs after sunroof has fully travelled.
    Switch to full closed.... press and hold switch for 5 secs after sunroof has fully travelled.
    Switch to full tilt.... press and hold switch for 5 secs after sunroof has fully travelled.
    Of course this all assumes the sunroof actually moves...
    ... if it doesn't then you're looking at fuse 3 in the Passenger Fusebox (longest strip of fuses, 3rd from top)...
    ... and after that comes narrowing down if either the switch, motor or parts/wires in between have failed.
    Jun 2011
    Skegness
    Spot on Handyandy, Reset the limits and all working again, thanks for your help
    now..... whats for dinner
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Glad to be of help.
    Dinner ? ..... not a clue.... I'm off to the pub
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by Sigmacca View Post
    Meatballs....
    If I disconnected the battery at all then it required a simple reset of simply pushing the button in and waiting for it to catch up to itself...
  1. electric tailgate opening when car unlocked
    By dreams3577 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 19:17
  2. electric sunroof
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2012, 11:52
  3. electric sunroof motor and light panel
    By rorycarz in forum Parts for sale
    Last Post: 5th November 2008, 16:46
  4. electric sunroof motor and light panel
    Last Post: 7th September 2008, 13:22
  5. Electric Sunroof & Parkpilot
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 10:21
vectra opc concept
vectra c sunroof fuseVectra electric sunroofvectra c sunroof not working
