Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Power Loss Vectra V6 3.0 CDTI
    Oct 2009
    New Marske
    Default Power Loss Vectra V6 3.0 CDTI
    I was driving home tonight , pulled out from a slip road put my foot down looking over my shoulder to check for traffic, when I thought I was in the wrong gear and had hit the Rev Limiter as there was a drop in power, I changed gear thinking nothing of it, as I accelerated up I suffered another loss of power, this time I looked at the Dash to see that I was only hitting 3k rev's yet the car was giving me the impression it wanted to change up,
    I did a few checks at different speeds and gears, it seems that the car has become limited at 3000 Revs, then Further along the road the light came on with a cand and spanner, I switched the engine off and back on the light went off but I still can't do more than 3000 Revs, everything sounds OK..??? and the car drives normal.
    Jun 2011
    Elland
    There are a number of things that could cause this - some fairly benign and some a bit more involved. If you can get the fault code(s) read, it would be a great help.
    Have a read of this thread... but you might scare yourself along the way... you'll see what I mean about getting the codes read
    http://www.vectra-c.com/forum/showthread.php?t=104017
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    First thing to do check all the vac pipes are connected
    Oct 2009
    New Marske
    The code it has is 0093
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by renwich View Post
    This points to blocked SCV's I'm afraid...or if you're lucky a blocked fuel filter only.
    Quote Originally Posted by Celes View Post
    Could this be yet another owner affected even though it was claimed it could not happen on the later engines
    Post the engine number and compare against the list
    How long have you had the car?
    Is it covered by a warranty?
    Jun 2011
    Elland
    Sounds like worst case is SCV. Best case is either a blocked fuel filter and / or air in the fuel lines. I mention the latter in the link I posted. So far replacing the fuel lines in tbhe engine bay and fitting a new filter has worked for me (actually fitted a Racor marine one, as boat bits are a bit more generic and I know I can make good airtight joints).
    Try replacing the fuel filter, if it cures the problem, great. If the cure is only temporary, then it's likely one or more quick release joints have failed and air is being drawn into the fuel system. There is no lift pump on the V6, so a leak allows air in. This causes fuel starvation and symptoms similar to blocked SCV.
    If you change the filter element yourself, you will need to top the filter body up through the bolt hole, whilst maintaining downward pressure on the assembly to maintain a seal. With pressure maintained, replace and tighten the bolt. If you don't do this, you will leave a big air gap at the top of the filter. Bear in mind when you top the filter up, there is a possibility of contamination from dirt around the bolt hole, so clean it before reassembly (this is another reason why I did not buy a VX filter: I also put a hand primer bulb in the system, so I can reprime without introducing contaminants.
    If this makes no difference whatsoever, then it is likely the SCVs are shot. This is an involved job, as they are located on the fuel pump, which has a few hours of labour's worth of manifold etc. shoved on top of it.
    http://www.vectra-c.com/forum/showthread.php?t=142272
    From Field Remedy 1957:
    Field Remedy: 1957
    Subject: Engine Y30DT, High Pressure Pump - Lack of power during acceleration
    Models: Engines: Option:
    Vectra-C 2003...2007,Signum 2003...2007 Y30DT| Z30DT,Y30DT| Z30DT
    Complaint: Engine lack of power during acceleration. During investigation with TECH2 a pressure drop between actual rail pressure and desired rail pressure is visible.
    Cause: Blocked suction control valve (SCV) within the high pressure pump.
    Production: Modified production process (earlier changing of manufacturing tools, improved cleanliness) implemented at supplier. Countermeasures were implemented with engine number 69692 (01.09.2006).
    Aug 2009
    Ascot
    out of curiosity were is ur engine number?
    Nick
    Oct 2009
    New Marske
    I had the fuel filter changed, it was great for about 10 miles then did the same thing, I took it to another garage who recommended a local scrapyard who apparently specialists in Vauxhall Diesels, I went there and the guy said Instantly it was the DPF filter and I should run the car at 3000rpm for 30 mins, I've also been reading about the Vacuum pipes and the similar symptoms.
    Does a 56 plate Vectra 3.0ltr V6 elite estate have a DPF..??
    Where Do I find the Engine Number ??
    thanks for the help Btw
    Jun 2011
    Elland
    Quote Originally Posted by s2yob View Post
    Nick
    On yer V5. Don't go grovelling around trying to find it on the engine, it will probably take 5 hours of strip down to access
  1. vectra 3.0 sri cdti: 75 % power loss. No inection
    By mtqn in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:47
  2. Vectra c 3.0 cdti ( loss of power )
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 20:58
  3. Loss of power diagnosis Vectra 1.9 CDti
    By MT82LFC in forum Engine & Drivetrain
    Last Post: 17th June 2011, 20:58
  4. Help with Vectra CDTI SRI 150 - Car loss of power
    By dan912 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th May 2011, 08:59
  5. Vectra CDTi 150 - Loss of Power
    By Chappers. in forum Engine & Drivetrain
    Last Post: 4th January 2011, 23:37
vectra c 3.0cdti loss of power
vectra v6 turbo diesel lost power
