Thread: engine fault please help
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default engine fault please help
    Guys need your help, just fitted another 1.8 engine as the old one blew a whole in the bottom, and after fitting it runs like a bag of poo. opcom it and get the following
    Total number of fault codes: 2
    P0340 - Camshaft Position Sensor Circuit No Signal
    (04) - Present
    P0202 - Cylinder 2 Injector Circuit Open
    (04) - Present
    Ive done the timing and as far as i am aware its alligned properly ive also replaced with original injectors. Ive checked everything i can see but cant find anything
    can anybody help please
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Take it nobody has a clue
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try cleaning both crank and cam sensors with some electrical contact cleaner.
    Jun 2011
    Elland
    'no signal' and 'circuit open' means those items are either faulty, or not connected, or there is a break in the wiring elsewhere...
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    cheers guys, found the fault, cam shaft sensor wires were worn and touching each other and the injector fault was because the plug for injector 2 wasnt sat properly, all sorted now!!
    cheers
    Jun 2011
    Elland
    Jobsagoodun, then
  1. 2.0 dti engine fault
    By huddsy in forum Engine & Drivetrain
    Last Post: 8th April 2011, 21:36
  2. Engine Fault?? Need Help Please !!!
    By bigpaw35 in forum Engine & Drivetrain
    Last Post: 6th August 2009, 21:47
  3. Engine fault ???????????????????
    By tony24 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 18:11
  4. Engine Fault Code
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 18:34
  5. Engine Fault
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 13th December 2005, 22:08
