Thread: New bushes?
    Regular Member Chez's Avatar
    Jul 2011
    Warwickshire
    Question New bushes?
    Hi all. Please can I get some more advice? All my bushes on my vectra c dti sxi have started to go - has done lots of miles. Which make would everyone recommend please?
    Regular Member Jezzy's Avatar
    S.E
    There are a hell of a lot of bushes on the Vec's suspension, I doubt they've all "started to go", so can you be more specific? There's no one "make" that can be recommended - the choice is usually either genuine GM, branded non-OEM parts from somewhere like EuroCarParts or no-brand ebay ones. Which one is suitable depends on which bush you're referring to; for example for ARB bushes buy them from Vauxhall, whereas for rear upper control arms try ECP as Vauxhall ones are quite expensive.
    Jul 2011
    Warwickshire
    Lol ok I'm with you . The mot advisories say that it is all the anti roll bar bushes - I had missed that bit out sorry. Many thanks for the information.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    All the arb bushes, so that'll be about a tenner from vx for the lot, ok at a push maybe 15 quid
    Jul 2011
    Warwickshire
    Smile
    Ah that's ok then , then I just need to find my oil leak and change the brake pipe front to back and all advisories done ! Happy now
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Brake pipes are easy to replace on the vec-c they are even sectioned form the factory near the front subframe, can easily replace the pipes going to both rear calipers without dropping the tank, just need to shape the pipe before you install it behind the tank.
    Jun 2006
    Kirkintilloch, Scotland
    Quote Originally Posted by XPCobra View Post
    Do you know if it is the same for the estate?
    Received a warning at my last MOT about corrosion on the two long pipes which run under my car. (a 2004 elite estate). I was thinking I would have to drop the tank.
    Thanks Dave
    Jul 2011
    Warwickshire
    Smile
    Thanks again for everyones invaluble help x would love to get to one of the meets and have a gander at everyones vecs and see what can be done x
  1. A.R.B Bushes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2011, 21:39
  2. arb bushes
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 09:51
  3. ARB bushes
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 00:29
  4. arb bushes
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 14:54
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
