Thread: Turn Signal Lamp/Indicator Warning
    Warrington
    Default Turn Signal Lamp/Indicator Warning
    I have a Vectra C facelift and I am having trouble with the indicator light on the front passenger side. The warning message 'Turn Signal Lamp' is displayed on the infosystem screen. The indicator seems to work intermittently - so when I get the warning a bit of a fiddle under the bonnet the indicator works fine. However, I just have to go over a few bumps and the message appears on the screen (the indicator click is also double quick). Back under the bonnet and a quick knock in the right direction and it works again. I have also made sure that all the fuses are fully pressed home. I noticed from previous posts http://www.vectra-c.com/forum/showthread.php?t=109719 that to replace the bulb is a major headache (remove the bumper!) but it sounds like I may not need to do that. Any suggestions on what might be causing this?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Change the bulb mate
    Most certainly will be a poor bulb.
    11 Post(s)
    Quote Originally Posted by Nimbus View Post
    A minor inconvience. It really is no big deal to remove the bumper.
    Quote Originally Posted by tony-1977 View Post
    Or a dirty contact where the multiplug connects to the headlight unit or the bulb contact itself.
    Feb 2011
    Selby
    My vote is for a failing bulb. Quite often the filament breaks near one of the supports - but because it's fairly well held in position there, the ends touch and it works most of the time. There's also a slight electromagnet effect because the wire is coiled which will help hold the ends together. But a few bumps and the ends are too far apart for it to conduct. Give it a tap and they realign.
    Change the bulb. I've never done it on a facelift, but have read the manual, and can see that actually it's not that hard at all.
    Warrington
    Thanks for your replies. I went to Halfords today to buy a new bulb and they fitted it for me, just popped it out and put a new one in. A bit of a cop-out but seriously I am no good at stuff like this. Appreciate your responses.
    Nimbus
    May 2012
    tyne & wear
    Just to confirm, I went to Halfords today also,
    A Young lad fitted it in 1 minute flat (He did have very small hands I might add)
    Leave your Bumper alone!
    well worth total of £8
    11 Post(s)
    Quote Originally Posted by gradair View Post
    How much!!!
    I'd sooner remove the bumper and refit it myself (¼ hour) and save £8 for the beer fund.
    Sep 2012
    Leeds
    "The indicator seems to work intermittently"
    Isn't that what they're supposed to do?
  1. turn signal
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2012, 22:15
  2. How can I replace the front turn signal bulbs?
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2010, 12:49
  3. How to remove turn signal stalk
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 16:58
  4. 04 vectra turn signal problem
    By azn_007 in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2007, 22:43
  5. Fault warning lamp
    By David2452 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2006, 21:55
vauxhall astra turn signal lamp error
Vectra c turn signal lamp
my vectra says turn signal lamp on
vauxhall vectra indicator warning
turn signal lamp vectra
turn signal lamp astra
myn2006 vectra says turn signalmlamp on
Vauxhall astra twintop turn signal lamp warning
vectra c turn signal programming
