Results 1 to 10 of 24
Thread: help with blower resister
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default help with blower resister
    need some help im sick of the blowers on 4 all the time due to resister
    right
    i brought a resister from ebay brand new got gm tho it worked for about 2 mins and packed up the bloke sent me another one today but that dont work at all ive tested the wires that go in the resister and the results are as follows (in volts) so i take it its the resisters that are no good or is it my car?
    Green wire
    speed
    1-0.00
    2-0.00
    3-12.03
    4-0.00
    Gray
    1-12.03
    2-12.03
    3-12.03
    4-0.00
    blue
    1-0.00
    2-12.03
    3-0.00
    4-0.00
    blue and gray
    1-0.00
    2-0.00
    3-0.00
    4-11.10
    when resister was connected the readings never went no more than 0.05v
    Oct 2009
    Sandwell
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Changed mine 3 times only to find out it was the motor, worth getting it looked at before spending to much
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    Quote Originally Posted by Badger59 View Post
    i agree with badger59 i replaced mine only lasted 7 months
    only works on heater 4 only
    VAUXHALL VECTRA C & SIGNUM HEATER RESISTOR 9180020 NEW
    this is the part number
    mine broke when i had water coming through the pollen filter which was blocked with leaves
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    the thing at the top isnt a resistor.......its a fuse.
    West Sussex
    Quote Originally Posted by Al 22 dti View Post
    It seems to me that the fuse blows because there's resistance from the motor, often cause by rain water getting in through the pollen filter because the drain is blocked. When mine went I gave the motor bearings a good soak with WD40 and it's been fine for 2 years. I had a lot of water come in at the time and I could feel that the motor wasn't running freely, so there's no point in replacing the resistor or fuse if the motor isn't free.
    Feb 2011
    Selby
    Yep - that was my reasoning too.
    There's a thermal fuse at the top of the resistor pack so if the air in the duct gets too hot from the resistors (which slow the motor down by dissipating power as heat) then it breaks the connection in order to prevent damage to the plastic ducting and potentially fire breaking out.
    So if the thermal fuse keeps blowing (ie only full fans speed works because it's unable to drop the voltage with the resistors) then you really should investigate why it's getting so hot.
    The most obvious reason has to be that the air flow isn't fast enough because of a blocked pollen filter. It could be other things (slow motor due to stiff bearings, a blockage in the ducts etc), but the pollen filter gets mucky so quickly that this has to be the main candidate...
    Oct 2009
    Sandwell
    tbh i dont think it is the fan the resister dont even get hot when on 1-2-3 or 4 so i guess it is the resister (i hope so anyway)
    Regular Member hagga's Avatar
    kingswinford
    when it's at No4 the resistor isn't used.. but at the other speeds it will get hot... it's possible that the motor is at fault but unless it's making a racket I'd say the the bearings/bushes are ok and maybe an impeller issue/blockage resulting in reduced flow/resistor cooling. If when it last worked the blower blew like a good'un I reckon the 'fleabay' units is really cheap and nasty... you should beable to get one much less than stealer price but as we know there is some right $hite on there... try another seller
    Oct 2009
    Sandwell
    it all worked fine with the first ebay resister on 1.2.3.4 then i tried o fit it in the grove and it wouldnt fit so i took the GM resister holder off and swopped it but i think i put it on the wrong way because when i put setting 1 on it was on like setting 3 , or do you think ive blow the motor in the blowrr by doing this? i thought becuse it works on 4 the motors fine and just needs the resister to lower the speeds?
  1. I cant get the link for fan resister
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 12:53
  2. Resister pack
    By sebadee in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2011, 10:33
  3. resister for blowers
    Last Post: 6th August 2011, 12:33
  4. heater resister were from?
    Last Post: 8th March 2011, 14:35
  5. resister
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2009, 23:25
