Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: I really want traction control.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Default I really want traction control.
    i really want traction control in my cdti 150. ive got the button that lights up but nothing happens. ive look all over the net on how to retro fit it with no success. what would happen if it changed the abs module with one that has tc would that work.
    milton keynes
    If you changed to correct ABS unit , you would still need to add a wire from the TC button to the ABS unit , it either pin 3 or 4 on the ABS unit , someone else will confirm this.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    but for the tc to work would i need the new abs module reprogrammed or tech2.
    milton keynes
    you would need it to be coded to your car , but the ABS unit needs to be capable of switching TC on and off.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    do you know the abs part number.
    VOTING UKIP IN AVELEY
    8 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    hmmmmmmmm theres me thinking the T/c switch switched it off ...
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    erm - you DO have traction control.. you dont have the functionallity to turn it off
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    no sorry ive only had the car 3 months i brought the tc switch and fitted it but nothing happens. i had it serviced on Monday i asked the guy if my car has tc he said no also theirs no light on the dash when the wheels do spin. so im thinking if i get the right abs module and reprogram it should that work. also does anyone know the part number for the abs module with tc?
    Full Member Big Sig's Avatar
    Quote Originally Posted by AntSSSS View Post
    Unlikely unless it was a factory option as it was only standard fit on the big engine cars. Its a 56 plate, so its a facelift.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i know the wiring looms are the same right and tc uses the abs sensors. so i dont see why fitting a new abs module wont make it work.
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
