Results 1 to 10 of 11
Thread: Abs problems
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Abs problems
    Hi all. I have just changed the bearing/hub assemblies on the rear of my 2T..the annoying drone has now gone BUT I now have the abs lights up on my dash and my speedo has gone awol too....
    Any ideas?? I have vnow disconected the battery fto see if this resets anything but in truth am cluess as to whats gone wrong..
    Barrow In Furness, Cumbria
    Need to get the codes read really to see which sensor it is.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    have you checked the connector plugs are correctly fitted to the plugs in the middle of the hubs? I imagine you have but just in case...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    WGAF#5
    agreed sounds like the speed sensors not connected properly and is causing the issue
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I've turned the plugs up side down,backwards,upwards and even replaced one ...didnt know the speedo worked off the rear
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    pathetic i know but...which is the correct way round for the plugs?..any pictures available
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Id put the plugs on upside down......hada look at a neighbours and swapped em over. Lights out on the dash,speedo working..halfway through the first drive the chuffing abs lights came back on!!
    Jun 2009
    South Coast
    yes speedo runs off the front wheels on a vectra mate, just about always the drive wheels on car.
    I did a rear hub on Lizard's car about a month back, i thought they only clipped on one way, isn't there a sliding plastic lock thing on the plugs that secure them to the connections on the hub. We did not have to disconnect the battery when we did this job.
    if you can do the old paperclip test and read off the codes it should hopefully point out whether you issue is front or rear.. If the rear hubs have dodgy abs sensors in them then they will screw up the abs system until sorted.
    To see whether it is your new rear hubs I would disconnect your battery and then jack up the rear of the car, disconnect the plugs from the new hubs and get the old hubs out and rest them on something so that you can reconnect to them. Reconnect your battery and see if you problem is still there. If the abs lights are sorted then it indicates a crap product that needs to be refunded.
    Let us know how you get on..
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Caveman..why dya think the speedo stopped working,then worked again once id put plugs back on the rire way round??
    Both the plugs did have blue clips but have now disappeared...I ended up having to use the flat head of a screwdriver to push the plugs into place..the rubber seal inside was that tight,tbh i dont see how they cuda worked loose.
    Jun 2009
    South Coast
    dunno mate, was sure it was the front, buy could be wrong. was going by what a guy at a rolling road told me, I had asked him the same question... seems thats another one whoes knowledge i will take with a pinch of salt.. He must have meant the other way round or i misheard as you do not want your speed showing how much you are wheel spinning.. so ignore my woefully incorrect statement on that.
    I was not aware your speedo was working again now though.. so you just have abs light on now then.. I think you wrote post 7 while i was responding with one hand while feeding my daughter with the other...
    your getting there, well done, maybe try a battery disconnect for 15 mins... were the hubs from VX? Are they the same part for all the models?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
