Thread: screeching when starting ??
    Regular Member mccluskey119's Avatar
    gourock
    confused screeching when starting ??
    Hi guys. got an occasional problem when starting the car sounds like a loud screeching/spinning noise?
    Its not the ticking of the starter. but i dont know if it could be the teeth on the starter away. thats just a guess. if anyone can help id appreciate it. it doesnt do it all the time it can go days without doing it.
    thanks
    Paul
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Tbh it sounds more like a dodgy aux belt or tensioner
    Jun 2011
    Elland
    Could be a bearing in the starter motor.
    If it cranks the engine normally, then screeches for a only a second once you turn the key to pos.2, then stops the noise with the engine sounding fine, then it's likely the starter motor bearing. Anything that carries on screeching once the engine's running is a different fault.
    Dec 2010
    OXFORD
    sounds like the alternator belt,could do with a tweek?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    tweak or dress the belt..OR change it..cheap n easy enough..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    as said above 99% that its the aux belt tensioner failing
    easy to change and lovely and silent once youve done it
    Jun 2011
    Elland
    A slipping belt makes a very characteristic sound, so does a knackered starter bearing.
    Belt slip sound: http://www.theaa.com/motoring_advice..._belt_slip.mp3
    gourock
    Thanks guys i'm just waiting to hear it again . just to clarify there is no problem of noise when car is running its just in the occasional start up ?
    paul
    gourock
    Just to update Been to the garage and he thinks its the starter. on another note when on the motorway the other day the car seened to loss power and felt like it was dragging itself when trying to over take the eml came on and the car went into limp mode couldnt rev it over 3000 revs had the light reset and new maf fitted . didnt change anything. so the old one was put bk on. now the car can rev right through. Took it a spin there but doesnt seem quite right when booting it. the car is not fast i know but im sure theres something wrong. im not sure what else could cause this ?? Any opinions guys
    thanks paul
  1. Front brake screeching!
    By Mogsy007 in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 20:17
  2. Screeching noise from back
    By Danialj32 in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2010, 22:59
  3. Screeching sounds when cold?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 12:32
  4. Loud Screeching noise
    By lesbo in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 10:11
  5. Knocking and screeching
    By Fulgrim in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 17:42
