Results 1 to 10 of 13
Thread: 2.0 DTI engine spanner light?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default 2.0 DTI engine spanner light?
    hi guys, ive got the dreaded engine electronics spanner light on my dash which pops up shortly after starting the car and goes away after a minute or so. there is no change in vehicle performance, mpg or anything else - but this light sucks!
    ive read elsewhere on the 1.9cdti engines this is down to a glow plug failure, could this be the same for my car?
    it happens whenever i start my car from cold but not necceserily after being turned off for a short time and restarted.
    If so, any idea why this has come up, as i only replaced my glow plugs in jan - although they were ebay cheapies!
    West Sussex
    Quote Originally Posted by Thom View Post
    You may have answered your own question with "ebay cheapies"
    Certainly the light coming on for that short time indicates glow plugs.
    You'll need to test them. I bought a set of NGK glow plugs from ebay, £35 delivered, I resisted the ones that cost £20.
    Nov 2010
    UK
    i actually didnt think something that simply has to get hot could deteriorate so quickly but it may seem they have - the cars getting a service in a couple of weeks when i have the time/money so i'll have a look at them then and stick some decent ones in this time!
    Thom
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    I believe on the DTI the glowplugs are only used when the outside temp is 5deg or below, so in winter you'll see the glowplug light come on then off when first switching the ignition on. So in this weather they won't even be used so unlikely it's making the EML come on.
    It could be a hundred reasons it's coming on, only way to pinpoint it is to have the codes read. Could be a vacuum thing on start up?
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    If someone near you has tech2 you will be able to get the codes read and try to pin point the problem.
    Regular Member Innes's Avatar
    Plymouth
    Where are you located Thom?
    West Sussex
    Quote Originally Posted by si_hoss View Post
    Even when it's 18 degrees in the morning my glow plug light comes on for a second. I only changed them last month and since replacing them the EML light stays off, prior to that it would always stay on for a few seconds.
    Nov 2010
    UK
    hi guys, im located in Durham in the North east - but as a student im concerned about the cost of tech2'ing my car - would it be pricey to have a list printed off - i assume only vaux can do it properly?
    I'm going to try the glow plugs as the car drives fine but does only run on 3cylinders for a second or two on startup (thought it was normalish!) if tech 2 is cheap enough ill do that too as a list would be nice however needing 4 new tyres i dont have much money!
    Plymouth
    THom, start a new thread on here called. Can anyone read my codes in Durham area? Alot of members have code readers and are happy to read the codes for you if you drive to them and most of the time it wont cost you a thing apart from maybe a 4 pack of beer and as a student I bet you've some lying around somewhere!
    north east
    When you say durham do you mean the actual ciry or surrounding villages ?
    if your willing to travel I have a Ms509 id happily hook up but i cant guarentee it will read the DTI as they are pedantic at best.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  3. Spanner Light and Engine Management Light
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 13:42
  4. Engine and Spanner Light Before I Start The Engine
    By corderz in forum Engine & Drivetrain
    Last Post: 24th March 2011, 18:48
  5. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
