Thread: My car is a bone shaker
    Jun 2011
    machynlleth powys
    Default My car is a bone shaker
    Hi there i have a cdti vectra 150 as you probably know as i have writen a few threads on here lately i just want to get to the bottom of what is wrong with my car.
    the main problem is that it rattles like hell when you put your foot down. push the clutch in an rev it .... nothing its fine?? its had a new flywheel and clutch and injectors have been tested 1 needed replacing. it still could be an issue with either of them but i just dont know.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    did u change the 3rd injector harness?
    Jun 2011
    machynlleth powys
    do you mean the plug on the wires that plug into the injector?
    if yes then the local garage fitted a new plug as the old on was loose that was done before the injectors went for testing
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    It wont be the engine if it goes away when the clutch is down!, you have a faulty dmf or a gear box problem by the sound of it., coming your way'ish fri & sat (barmouth) just a couple of days for a change of scenery.
  1. control arm same as wish bone??
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 22:52
