Thread: 1.9 CDTi Intermittent smoke, smell, noise..
    Regular Member Sten's Avatar
    Feb 2011
    Paisley, Scotland Drives: Vectra C GSi & Corsa
    Default 1.9 CDTi Intermittent smoke, smell, noise..
    Sitting at the lights today I noticed smoke around the car, as I was sitting next to an old transit I assumed it was coming from that but sadly as I continued on my way I realised it was coming from my car.
    It's happened on 2 occassions now and disappeared again.. smoke appears to be coming from under the car, or from the engine area - not from the exhaust, the smoke isn't dark.. bluey-white I'd say. When this happens there's also a burning smell and the engine appears to sound 'rough'... seems to happen when the engine is up to temperature.
    Any thoughts?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Split breather pipe(s) / turbo pipe(s) / Vacuum pipe(s)?
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    As yours is a diesel, i would say it was doing a clean out of the Diesel Particular Filter (DPF).
    If you look at the instant fuel consumption it world normally read 0.1mpg, when it’s doing a clean, it will read 0.9mpg, the acceleration will also be poor, if you drive around it should be cleaned out a little quicker, if your unable to drive around, it can get a bit smoky, & very hot, i would recommend not turning off the engine until the car has completed the clean out.
    For more information on this subject type in DPF in to the search box at the top of the web site, this subject has disused many many times.
    Hope this helps.
    Feb 2011
    Thanks guys, I'll have a check for pipe issues if it happens again.. the DPF did cross my mind, fingers crossed that's all it is.
    Sep 2010
    Milton Keynes
    sounds like DPF to me mate
    Feb 2011
    notts
    just a random does youre exhaust blow a little aswell from the front?
    Feb 2011
    Not that I've noticed.
    I gave the car a good run today and it drove as sweet as a nut.. I guess that would back up the DPF theory. Fingers crossed.
  1. Fume smell, smoke test??
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:07
  2. Best/Quickest way to eliminate smoke smell in new car?
    By mpc in forum General Motoring Chat
    Last Post: 9th September 2012, 15:45
  3. intermittent blue smoke
    By rec in forum Engine & Drivetrain
    Last Post: 9th July 2012, 19:23
  4. 1.9cdti black smoke/smell
    By dubsrus in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:58
  5. Replies: 0
    Last Post: 4th March 2009, 14:34
vectra c intermittent smoke
