Thread: 2.2Dti Fuel Pump issue's?
    Cheshire
    Default 2.2Dti Fuel Pump issue's?
    Are there any problems with the 2.2 Signum / Vectra C diesel fuel pumps?
    An 'expert' has informed me that they are renouned to fail. Is this true? Is there a 'fix' if so?
    Presume its the PSG16 pump?
    Do these have a lifter pump in tank?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    The VP44 PSG16 pump (one fitted to the Vec C) has been rumoured to fail quite a lot yes. Actual failures do seem pretty rare though. It seems to be only one of a small number of things killing them though. Either dry solder joints on the ECU, the sensor inside the pump giving up and no longer reading correctly or the pump suffering from a lack of lubrication. A lot of people on here have now started to put in 300ml or so of 2 stroke with every tank of diesel to get around this.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    They don't have a lifter above the tank, like the 1.9CDTi's do.
    My 2.2 DTi has done 100k miles now with no issues. Add 200ml of 2-stroke oil every two fillups to keep the pump lubed and quiet
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i too add 2 stroke to every 5 tank full of fuel seems quiter and a little more reponsive and it has now done 178000 miles
  1. 2.2dti fuel pump
    By cliff75 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 16:02
  2. 2.2DTi Fuel pump assistance please
    By sigtim in forum Engine & Drivetrain
    Last Post: 10th November 2011, 15:24
  3. Bosch fuel pump vp44 2.2dti
    By davesignum1988 in forum Engine & Drivetrain
    Last Post: 12th September 2011, 13:41
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
psg16 pump issue
vauxhall vectra 2.2 diesel fuel pump www.vectra-c.com
