Thread: engine cutting out.
    Aug 2011
    newquay
    Default engine cutting out.
    hi i am new on here. i have got a 54 plate vectra 2.0 dti estate.it has 79,000 onthe clock.when out driving the engine management light comes on loss of power. switch it off then it restarts.it feels like it is about to run out of fuel.it does this nearly every day then its ok for a while. i am afaid to take my wife and children out in it because i cant trust it. ihave changed the fuel filter and glow plugs. can any one help?
    Engine : 1.9 CDTi
    Have you had the codes read?
    Aug 2011
    newquay
    no codes have shown up
    Engine : 1.9 CDTi
    What equipment was used because if the light came on it has stored a code.
    Aug 2011
    newquay
    i spoke to my mate who said the only code that came up was battery dissconnected at some point he cleared this. as far as i know there are no code numbers present.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Would be worth getting the codes read again, may be one stored but not "current", so not putting light on
    Jun 2011
    Elland
    Some readers / software can only investigate the 'engine' light, not the 'spanner' light codes.
    I made this mistake with my first code reader - thing said everything was OK, even though the spanner light was shining brightly!!
    Aug 2011
    newquay
    the engine management lights up then loss of power. turn off engine then light is out ,but plays up now and again
    Aug 2011
    newquay
    cannot find anyone in cornwall who can check for codes for me
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi jas
    as the lads say you really need the codes read,guessing is hard work but have you ever cleaned the egr.you may find it's carboned up,but you usually get an 0400 code
  1. engine cutting out help!!!!
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:23
  2. Engine Cutting Out
    By FlaminDTi in forum Engine & Drivetrain
    Last Post: 25th November 2009, 18:50
  3. Replies: 3
    Last Post: 28th April 2009, 19:49
engine management light came on then engine cut out on vectra c
