Thread: 1.9CDTI Starting Problem..it just clicks once
    Rustington
    Default 1.9CDTI Starting Problem..it just clicks once
    Hi
    I'm after a little advice if possible. My 56 Plate 1.9CDTI (150) Signum went for a service yesterday and all seemed fine. My wife picked it up, had no problems using it all day doing short journeys.
    I went to start it this morning and as I turned the key to position 3 it just clicked once and did nothing. It felt like it might be an immobiliser issue so I got out of the car locked and unlocked it tried again...same thing, just a single click coming from the engine bay. I tried a few things (locking and unlocking with key etc) and then in desperation pressed the button to deactivate the internal sensor in the car, turned the key and hey-presto the car starts.
    Drove to work (45 mins) without problem. Got back to the car after work and the same problem. After several minutes and trying my new 'trick' it still didn't start. I then locked and unlocked the car using the buttons on the armrest, turned the key and it started.
    Got home without incident, turned the engine off and then tried to restart it an nothing except for the click. having been out a few time this evening trying different things it will start occasionally but mostly will just click when I turn the ignition.
    Having read the articles I can find it could be a number of things but before I go back to the garage I'd like to see if there are any fixes I can try.
    Any help gratefully received.
    FYI I am a real novice when dealing with car engines...
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Starter relay sticking, by the sound of it
    Glasgow
    Goosed battery.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by byebyeitsagsi View Post
    Goosed battery.
    Surely it would not start at all if it was the battery? unless it was jump started when flat?
    Rustington
    I'm pretty sure the battery is OK, I travel a good distance every day and it was changed relatively recently.
    Any idea which relay is likely to be the culprit?
    Thanks for your help!
    Gavin
    Rustington
    Just thought I'd update this just in case anyone finds this on a google search. took it back to the garage and they advised me that it was the Starter Motor. Changed it out, £280 down but I car now working.
    Thanks for the advice everyone.
  1. Not starting just clicks!
    By frigosolver in forum Engine & Drivetrain
    Last Post: 5th February 2012, 08:55
  2. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:10
  3. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  4. 1.9cdti whine when starting
    By mann3210 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 12:16
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
