Results 1 to 10 of 17
Thread: vectra steering clunk
    Aug 2011
    coatbridge
    Default vectra steering clunk
    Hi guys,
    This is my first post so be gentle...:-)
    The model is a 1.9cdti 150 on a 57plate.
    Im getting a slight clunk through the steering wheel when turning. the car itself has 31000 miles on and i've only had it under a week. I was going to give it back to the dealer to investigate but i want to be ready when they tell me the inevitable story "that they can't find a problem"
    I had similar issues on my 02 plate sri 150 a few years ago.Vauxhall subsequently changed the rack twice which didn't resolve the problem. The problem is very similar... The clunk is more noticeable when you are turning at low speeds like in a car park.
    any help will be much appreciated
    thanks
    stu
    Jun 2011
    brum
    Is it just one "clunk" as if it were missing something or jumping, or is it continous (not that im mechanically minded, but im guessing that information would help someone else figure it out)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does it do it when the car is staionary? At first guess i'd say the upper strut mounts need replacement
    either what john says or one of your springs has broken
    Aug 2011
    coatbridge
    Hi,
    The clunk seems to come from behind the steering wheel on the column. the 'play' is is more noticeable when engine is off and the steering wheel is 'wiggled' back and forward...i meant to say that the garage put it through its MOT...
    stu
    Sep 2010
    I think it's the front top shocker mount bearings. Mine did this, either at low speeds or at rest. Does sound like a clunk but it's the bearings.
    Can also cause the feeling of out of balance wheels sometimes ..
    Aug 2011
    coatbridge
    Its funny you mention that chewy.
    the steering vibrates from 65 upwards. (im not obviously going to say what though..)
    i suspected wheel balance....
    im not holding out much hope of repair from the garage...E*ans H*alsh*w...
    stu
    Sep 2010
    Don't,. they will charge you £165 + VAT - and say it's 3 hours work. (EH in Hull / Bev?)
    I got mine done locally for £90
    Sep 2010
    these parts are covered up to 37,000 miles (mine went at 47,000) .. but you will be out of the MF warranty too so despite being in on the mileage,.. your too old!!
    Aug 2010
    Derbyshire
    Just check where the steering column (bottom) connects to the rack.
    My steering wheel had play in it, more of a looseness rather than a clunk though.
    Anyway nipped up the pinch bolt on the bottom of the column, job done no more play at the wheel.
    Apparently they do work loose on the Veccy.
    Mick
  1. Steering play/clunk
    By byebyeitsagsi in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2013, 19:07
  2. clunk
    By matt.d in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 19:12
  3. clunk from steering
    By idobigmls in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 07:13
  4. i have a clunk
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 22:03
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
vauxhall vectra knocking noise when turning steering wheel
vauxhall vectra b clicking when turning
vectra steering clunk noise
vectra steering shaft rattle
vectra c weird knock
vecrea 2005 knoccking sound steering
vectra c clunking when turning
knocking on steering wheel vectra cdti
vectra cdti steering colum cluncking
vectra c steering column clunking
vauxhall vectra steering clunking
i get a knock from my vectra c under hard bracking but at ĺow speed
vectra steering wheel clonk
2006 vectra steering clunk
Vectra has clunking when turning
