Thread: MW new Problem
    Jul 2011
    devon
    Default MW new Problem
    Hi all,
    Have searched the forums but cant find anyone with the same problem.
    when stationary the recption on medium wave/am is fine even when the engine is revving up. However as soon as the vehicle moves from stationary there is a high pitched interferance that make listening to the radio impossible, as soon as the vehicle comes to a halt the reception goes back to normal.
    Has anyone else experienced this, if so what was the cause
    Also the CCr2006 HU really struggles to lock onto FM stations, even National ones-radio 1/2 etc, any suggestions on them, have seen the inline boosters listed elsewhere but was wondering if anyone had actually used these and if so did they work.
    Thanks in advance.
    P.S. forgot to mention its a 2003 vectra hatchback with a ccr 2006. have only had the car for two days and so far its brilliant apart from this problem.
    Feb 2011
    Selby
    I suspect you've got a break in your aerial lead, or the base of the aerial is damp internally.
    I have a CCR2006 in my Vectra, and FM performance is superb. MW is free of alternator whine too.
    Jul 2011
    devon
    Quote Originally Posted by rich r View Post
    Thanks for the reply, do you know of any way to test for the above or how to remedy,
    Feb 2011
    Selby
    Take the aerial unit off the roof - it's fixed on from below and have a look. If you've got a multimeter, test for continuity from the aerial lead at the back of the radio to the aerial itself.
    Sorry I can't be more detailed- I've not needed to take mine off so don't know what it looks like inside.
    Jul 2011
    devon
    Bump
    Full Member spennny's Avatar
    Blantyre
    I have similar issue, up until 2 weeks ago i could drive to work listening to eagle FM, now i have bad interference driving down the M3 , i have looked at the connections at the back of the stereo and there all fine, so i will look at the base of the ariel this weekend
    Feb 2011
    Selby
    I'm not sure, but I think the aerial has an amplifier/impedance matching circuit in the base. So if this isn't getting power due to a broken or corroded (due to water ingress) connection it won't give a very good signal to the head unit.
    Jul 2011
    devon
    thanks for the reply had a look at base of aerial and looks quite perished so have ordered a new one and will fit this weekend and see if that helps
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vectra c medium wave not working
